big block g body headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2010, 08:33 AM
Im in the process of building a street strip 81 malibu with a mild 454. I know that hooker and hedman both make headers that will work, although i would like the primary tube to be 1 3/4" instead of 2". So my question is are there any headers that will work for my application with minimal mods? Thanks
Old 02-11-2010, 09:05 PM
So i guess im stuck with oversized 2" primary hedders?
Old 02-11-2010, 09:09 PM
Did you look anywhere it took me about 5 seconds http://www.lemonsheaders.com/products.htm
Old 02-11-2010, 09:20 PM
ericnova72's Avatar
More for Less Racer
But have you seen their prices?? They better just magically arrive installed on my car for that kind of change. I'm guessing the Op is looking for a more economical solution.
Old 02-11-2010, 09:32 PM
Yeah SD Luck i did look anywhere, maybe you should have looked and you would have seen that it said MILD big block as in i dont wanna spend a thousand dollars on a set of hedders. Considering that is about 1/3 of what i spent on the motor, and also if you read the entire forum you'll see it says with minimal modifacations. I dont know about you but if i have to spend a thousand dollars on a set of lemon hedders then i really shouldnt have to modify them should i ?
Old 02-11-2010, 10:45 PM
Did not see where you said price was a problem.
Old 02-11-2010, 10:56 PM
No i didnt say price was a problem but i did say MILD 454. I guess from now on i should let people know that mild means i dont feel like spending a thousand dollars on a set of hedders!
Old 02-11-2010, 11:03 PM
Guy Hiltz's Avatar
"A" body Chevelle headers can be made to fit,but you might have to do modifications to get them to fit.
Guy
Old 02-11-2010, 11:10 PM
Thanks guy. i'll have to go that route and modify
Old 02-12-2010, 06:40 AM
Guy Hiltz's Avatar
When I bought my big block powered '86 Monte SS,it had what I believe were 1 7/8 inch Black Jack headers for an "A" body Chevelle,one tube was cut and a bend welded in to clear the clutch "Z" bar.Other than that they fit really good.Unfortunately,I'm not 100 % certain of the exact make and there were no markings on them.Last year I totally rebuilt my now 468 bb,and decided to go with a 2 inch Hooker Comp # 2455 header for a Chevelle.The right side lower control arm mount needed to be "clearanced",one of the motor mounts needed material removed,the clutch "Z" bar needed extensive work,(cut & rewelded),a couple of tubes needed to be dimpled,the brake proportioning valve needed to be moved.There are swap headers available,but they are very expensive.
Guy
Old 02-12-2010, 08:18 AM
Thanks again Guy. Ill order a cheap set for an A Body and modify where needed.
Big block chevy into a 91 S-10?? 12second6 General Rodding Tech 11 04-28-2009 06:43 PM
Big Block ???? jc4x4tug Engine 18 04-02-2009 09:04 PM
are Big Block Nova motor mounts different? tommytempest Engine 5 01-17-2007 07:30 AM
Block Hugger Headers vs Regular Headers 63ChevyII General Rodding Tech 7 05-07-2005 10:15 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
