big block hellp - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-30-2009, 04:10 PM
hevy chevy's Avatar
Thanks. Its A Rec Port Intake Any Way So I Don't Think It Would Work Any Way. Any Suggestions On What I Should Buy All That Is Done To My Big Block Is Its 30 Over.
  #17 (permalink)
Old 01-30-2009, 04:30 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
eldebrock performer or performer-RPM seems to be a good one what is the truck used for? 4x4 or 2wd street
is the rest of the motor stock? i.e. cam or headers?
  #18 (permalink)
Old 01-30-2009, 04:38 PM
hevy chevy's Avatar
2 wheal drive 3in pipes headers stock cam and heads but want to get some sound and pep
  #19 (permalink)
Old 01-30-2009, 04:47 PM
& matts38chev
id go Performer-RPM then itll give you room for a little improvement later
  #20 (permalink)
Old 01-30-2009, 04:58 PM
hevy chevy's Avatar
that's what i want bit by bit . hay do roller rockers make a big difference?
  #21 (permalink)
Old 01-30-2009, 05:03 PM
& matts38chev
id save that for later, unless just maybee
comp cams 1:72 roller tip will give you a touch more lift on that stock cam
Big block chevy into a 91 S-10?? 12second6 General Rodding Tech 11 04-28-2009 06:43 PM
Big Block 82 Pontiac Gran Prix william27103 Engine 3 03-30-2009 12:50 PM
Ford Big block 4 spd bellhousing bigblocktorino Transmission - Rearend 3 10-05-2006 03:56 AM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
