Big Block Installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2004, 06:32 PM
I am wanting to install a big block in a 71 chevy pickup that currently has a small block. Will I have to do any frame modifications or other under the hood mods to the truck to get it to fit in correctly?
Old 11-01-2004, 06:37 PM
Jmark's Avatar
Nope, should drop right in. Any chevy auto or manual bellhousing will bolt up too. Hardest part will be finding all the necessary accessory engine brackets.
Old 11-01-2004, 06:41 PM
Will I only need the motor mounts from the original application of the big block, and will I have to modify them to bolt to my frame?
Old 11-01-2004, 07:18 PM
TooSlow's Avatar
Beater Driver
Your small block motor mounts will accept the big block no problem. If you plan to run headers be sure to check with the manufacturer to see if they made them with big block or small block motor mounts in mind as the installed height of the engine may be a little different and this can cause some clearance problems.
Old 11-01-2004, 07:39 PM
How much weight will the big block add to the vehicle opposed to the small block?
Old 11-02-2004, 12:20 AM
benwantland's Avatar
I dunno, but for a project like this, you're going to have a lot of questions, and you might want to check out www.67-72chevytrucks.com
Old 11-02-2004, 11:20 AM
gpeak's Avatar
Maybe 200 pounds?
Old 11-02-2004, 12:33 PM
Siggy_Freud's Avatar
Wont add a whole lot of weight. If your worried about suspension handling it dont be lol. You might notice it a bit in the corners but not many people build trucks with cornering in mind anyways lol.
Bringing history and technology together.
Old 11-02-2004, 01:46 PM
Will it make a difference if the big block engine comes out of a two ton truck? As far as bell housings bolting up and firewall clearance.
Old 11-02-2004, 02:07 PM
As far as I've always known, a chevy bb is a chevy bb is a chevy bb.
It would be a lot cheaper for them to modify the sheet metal in the car to fit the engine than to redesign an engine for a different car.
It should fit fine and bolt right up to any GM transmission.
Old 11-02-2004, 02:12 PM
poncho62's Avatar
Wiki Edits: 5
Large Chevy gas truck motors (not sure about the 2 ton) were tall blocks, 366 and 427. They bolt up the same, but have smaller heads and are not made to rev as high. They do however have 4 bolt mains and steel cranks.
