Big block mopar oil pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2006, 02:34 PM
Good day everyone.Someone out there has attempted to install a big mopar eng. in a T or A street rod.My basic problem is the stock oil filter location is in the way of my steering.I am using a Corvair box and cross steering.Does anyone have knowledge of a pump cover that would turn the filter 90 degrees downward instead of straight forward.I have room if I remote mount the filter,but I don't want to do that if I can possibly avoid it.The simpler the better you know.Thanks, biggeboss.
Old 06-14-2006, 02:42 PM
spinn's Avatar
the people that i hear relocating, use a remote mount type rig. some claim it has cooling benefits too, but im still not havin it. you could try manciniracing.com see what they have to offer in the way of oil pumps.
great choice in powerplant, i hope it works out.
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 03:22 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
high volume oil pump question jstaten Engine 4 01-16-2006 12:56 AM
Oil pump ? 70gmcer Engine 9 11-20-2005 02:01 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 07:38 PM
