big block mopar oil pump gasket??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 12:49 PM
Hi, i'm having a hard time finding an oil pump to block gasket for a big block mopar. I found one in year one catalog, but i cant find one at a local auto parts store. Sounds silly but the oil pump gasket is the same gasket from 1959 on up all big blocks b and rb blocks, but no local store carries it!! If someone has a fel pro gasket# that would help. the gasket kit sould come with 1 gasket and 2 o rings. i have the o rings but no gasket. i have looked online but only found year one to have it. this is just crazy!
Old 11-09-2008, 01:52 PM
OHD's Avatar
OHD OHD is offline
I have never used them just a small bead of hitemp permatex, but if you just have to have one:
http://cgi.ebay.com/ebaymotors/NEW!-MoPar-B%2FRB-Oil-Pump-Seal-Kit-~NOS~-440-400-383-361_W0QQitemZ220307947566QQcmdZViewItemQQimsxZ2008 1107?IMSfp=TL0811071110006r23310
Old 11-09-2008, 02:52 PM
Thanks, i saw that online. i just thought i was missing something since mopar has used that gasket on every big block for about 20 years. If you by a oil pump the gaskets comes with it, and a full gasket set has it too. I wanted to finish the motor this weekend but i guess i have to order the dam thing
Old 11-09-2008, 03:44 PM
OHD's Avatar
OHD OHD is offline
I do not use the gasket on ANY mopar type RB oilpump. The oring(s) do the sealing and silicon takes care of rough surfaces.
I do not build cheap engines and do what is best..
Old 11-09-2008, 04:48 PM
Thanks, i have built alot of motors, if it has a gasket i use a gasket, but you are right. the o ring dose all the sealing. when i took the oil pump off the gasket didn't have a sealing surface. the oil pressure is in the tube sealed by one o ring. i just wanted some feed back.
Thank you! do you have a hemi?
Old 11-09-2008, 07:50 PM
OHD's Avatar
OHD OHD is offline
More than one and use either Plueger, ProSystems, or Titan oil pumps for wet sump systems. Aluminum blocks none of the old cast iron stuff.
Old 11-09-2008, 08:11 PM
cool i'm taking you'r word on the gasket. i no its right when i pulled the oil pump out, the small oring sealed up the oil galley. i think they have the gasket in case the seal leaks a little. but a little silicone will seal nicely.
Thanks for the help. i just dont want to pull the motor out because of a 5 dollar gasket!
thanks ohd
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
high volume oil pump question jstaten Engine 4 01-15-2006 11:56 PM
correct oil pump Blob Engine 1 12-18-2003 06:58 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
