Big Block Motor mount bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2003, 08:03 AM
Post Big Block Motor mount bolts
I need to know the bolt size for a standard 1998 454 engine mount. It's the 5 1/2 inch long bolt that goes thru the engine bracket and the rubber mount. A 3/8 bolt seems too loose and a 1/2 bolt won't go, sounds like a 7/16 should work, but I want to know the specified size.
Old 01-13-2003, 08:11 AM
Tazz
Cool
The bolt should be a 5/16 grade 8. The bolt will have what kind of looks like a star burst on the top of it. A softer grade bolt MAY snap off so if you use the lesser grade bolt put the bolt heads on the radiator side of the mount just in case the nut breaks off while you are driving then the bolt will stay in the mount.
Todd
