big block Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2014, 06:20 AM
Last journal entry: pickin' away
big block Nova
G'day all, I was wondering if any of you ever tried to put a big block in a late 70's Nova ? I have a '76 Nova and a 454 I'd like to put in it. I hear its quite a job since these cars weren't made for big blocks.
Name:	Fall pix 2013 034.jpg
Old 03-08-2014, 07:00 AM
poncho62's Avatar
Wiki Edits: 5
It will fit just as well as an earlier Nova, probably even easier since your car has front steer (steering linkages in front of crossmember)
The Following User Says Thank You to poncho62 For This Useful Post:
Buick b4 (03-18-2014)
Old 03-08-2014, 07:11 AM
ericnova72's Avatar
More for Less Racer
Fits easily, use headers meant for the 70-73 Big Block Camaro. The 75-79 Nova front subframe is the same(except for things like bumper mounts) as 70-81 Camaro.
Old 03-09-2014, 12:34 AM
TroyBoy's Avatar
Psychomotors
Good advice from these guys. You won't have any issues.
Old 03-09-2014, 05:24 AM
Banned
The nova is chevy's farmont. like the farmont that most mustang parts bolt on.. the nova can use most of the (iirc 75up) f-body parts..
T/A WS6 swaybars ,etc engine parts /brackets, brake upgrade kits, the taller front spindle kits..
Old 03-09-2014, 06:57 AM
Thanks for posting guys. I think I'll probably give it a shot. I allways wanted a muscle car!
Old 03-09-2014, 07:47 AM
Banned
before or during your big block install... add frame connectors if you put power in that bbc and set the car up to use it (hook)
Old 03-14-2014, 03:59 PM
Shouldn't be a problem. Thought about doing that with my 77 nova years ago. If you have a v-8 in it now, the front springs should be ok. If its a 6 banger, I would be ok but will set the front end down a bit. The front springs were light weight on some of the 6 banger novas.
Old 03-18-2014, 09:20 AM
Buick b4's Avatar
You can do it, one of my friends in Wisconsin put a 455 Big Block on his 77 Skylark which has the same body as yours.
Old 03-24-2014, 09:37 AM
BBC Nova
Actually, Chevrolet did manufacture a very few of the mid 70's Nova's with a 454. These were special order for Califonia Highway Patrol and I think some went to L.A.P.D. traffic units as well.
Old 03-24-2014, 10:49 AM
If you get that big block in it, make sure you put a sway bar on the front end if it doesn't have one. That extra weight will make it want to drift when turning hard. Yenko nova had the 427 I believe. some ss novas had a 396.
Going From Small Block To Big Block In '71 Nova... STATUTORY GRAPE Engine 4 07-13-2008 03:14 PM
Big Block in a 67 Nova??? WhoCares General Rodding Tech 2 08-17-2006 05:22 PM
66 nova big block 2chevy2 General Rodding Tech 7 04-04-2006 09:48 AM
Big block in Nova IROCZ Engine 2 03-08-2003 03:25 PM
Big block for my 73 Nova Hatchback? 73 Nova Guy Hotrodders' Lounge 7 02-26-2003 10:40 AM
