Big Block Pontiac Performace - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2004, 07:09 PM
New Member
Iam bilding a 37 pontiac and i wont a big block with a blower. But i dont know anything about pontiac. so some sugestions on what engine i sould find and what i should do to it. thanks for any help
Old 02-21-2004, 07:46 PM
astroracer's Avatar
All Pontiacs from the 326 up to the 455 use, essentially, the same block. They are all "big blocks". I would look for a 455. Cubic inches are king and this will do it for you.
Here is an article Car Craft did on a junkyard 455. http://www.carcraft.com/techarticles/116_0306_pont/
Look it over and ring back with any questions. Lots of Pontiac guys here...
Mark
Old 02-22-2004, 06:50 PM
As far as building a Pontiac for a blower motor go with a 455 with large chamber heads such as 4Xor 6X to keep compression down. Use good rod bolts as stock Pontiacs have a tendency to stretch, I recommend ARP for rod bolts. Also if you feel the need for better rods either 421SD or 455SD rods are the best that Pontiac made but stock cast rods will work. Use forged pistons and good rings and use a half groove main bearing as Pontiacs have tendency to have alot of force on the downstroke and will form a ridge on the crank over a period of time. Use stainless steel valves and have a reputable shop port and polish the heads and use good springs and roller rockers. As far as cams I'm not sure what to recommend on that one but check with some of better known builders that specialize in Pontiacs for what type of cam to use as far as cylinder pressure is concerned along with how much boost you may want to use along with whether to overdrive or underdrive your set up.
Old 02-22-2004, 07:02 PM
Rhansen's Avatar
Footbraker
These guys can help with your supercharger on pontiac motor.
www.sd-concepts.com
Old 03-01-2004, 08:37 PM
bullheimer's Avatar
NEVER use credit cards!
thanks astro for that cool link on a 455 hop up which would be about the same as a 400. i didnt see anything at the blower site for pontiacs. it would be expensive as hell tho. the main problem with pontiacs is the heads totally suck for the most part. a 326 is about the same as the 455 except the e heads dont fit. a friend put an edel intake and thorley headers on his 326 and didnt notice much of anything. like about. but we cant go out and get heads. there are some good poncho heads out there so you have to be carefull when you buy the engine or plan on buying them later. i've also seen a post where someone makes a crank to stroke the 400 to 462 and am trying to find the mfg.
Old 10-09-2004, 10:45 PM
New Member
Here's a link to a place that sells pontiac stroker kits . This one doesn't seem to steep. But they have an assembly to go from 487 - 501 CI.
And as for supercharging a pontiac, it doesn't seem to bad. I found a manifold for somewhere that was $500, not much more then a chevy. From there, the cost would be the same for anyother blower.
I'd like to see how a stock pontiac head with some light port work would handle boost. I think you coulld make big torque with a roots blower. I haven't done to much research yet as I am getting my T/A in a few days.
Sorry for bringin such an old post back up.
Old 10-10-2004, 12:11 AM
bonuts's Avatar
Got Ouzo for touzo
From your question, you don't really say you want to run Pontiac power. While Pontiac engines are just fine, they do cost a bit more to build compared to the Chevy Big Blocks.
I also guess from you wanting a blown big block your going to be spending some big dollars either way. Its really your choice, there are more after market parts for the Chevy's, so they are a bit cheaper to build.
Build what you want, but please keep it GM!
bonuts
Old 10-10-2004, 08:16 AM
are the pontiac and oldsmobile 455's the same?
Gary
Old 10-10-2004, 10:02 AM
Restore60s's Avatar
Big Block Pontiac
If you want to run a 455 Pontiac engine look for the YH engine if you can find one. Casting # is 9799140. You will find the YH code on the front of the block below the pass. cylinder head. The YH is a factory 370 HP engine. You will find it in a few 70 Pontiacs like the Bonneville or Catalinas. I built one back pretty much stock just some stronger rods and the only thing that was changed above stock was using the Lunati Pontiac Ram Air IV cam. That was paired with a Edelbrock intake and a HEI ignition conversion. The Ram Air IV cam picks up the bottom end and has a nice "chop" to it without bouncing all over the place and has no problem going into gear without a stall convertor. The rebuild with machine work was around $2,500. That's not a bad price for complete machine work and having everything replaced and upgraded. Linked to a Turbo 400 Transmission it will push you thru the drivers seat on acceleration. But it's a dependable, streetable engine. So without spending a fortune to make horsepower you can have it the way it used to be straight from the factory.
Old 10-10-2004, 05:26 PM
Will I ever get it done?
Last journal entry: Hood
Gary
Buick, Pontiac, and Olds were all different. The Buick had the distributer in the front, so easy to pick out. The Olds had a metal oil fill tube sticking up in the front of the engine. The bell housing bolt patterns are the same.
Old 10-11-2004, 04:28 PM
Tazz
69 LeMans
With a built 400 that runs STRONG all day long!! The engine is punched .060 over and the power is unbeliveable!! Probably a sin...or close to it!!
Tazz
Rat Rods Rule!
Old 10-22-2004, 11:09 AM
tempt's Avatar
Thumbs up 400 or 455?
If you can find a 455 that's great although they are kinda scarce.
e.g. took a whimpy 326:
I put Lunati cam, edelbrock performer RPM, and 2.25' duals on hedman headers and I can bend my '66 tempest out of a straight line when I hit it at 60.
Not so whimpy 400:
I am now building a '67 400 (yes, out of a catalina) with #143 10.5:1 heads (if you can find these heads, grab them, they have bigger chambers and valves). 75cc chambers. 1.92 intake valves! that you could punch out the edelbrock spec of 2.11 if you want to. (probably will)
point: (and I have one,) that you can do a lot with the heads to increase power. 4x and 6x are nice, but the ultra rare stock heads could be---- almost as good as the alum eddy's for a lot less. Do your porting/polishing get 1.65 roller rockers, oversize the valves and I promise you can build a 400 hundred that will require regular dental work!
tempt
Old 10-22-2004, 03:07 PM
Tazz
What are you talking about..a 400 is NOT whimpy at all. Lets go to the track guy and you put your money where your mouth is!! Wanta run...well do ya??? My Lemans agains your tempest...heads up........LOL Gotta love this hobby!!!
tazz
Rat Rods Rule!
Old 10-23-2004, 09:49 AM
tempt's Avatar
Gung Ho Tazz,
read my post again, the 400 is a great block with great potential.
425-475 h easy. Your Lemans sounds mean. Power to the Ponchos! Sorry if I offended, I meant no disrespect.
Old 10-29-2004, 11:45 AM
bullheimer's Avatar
hey tempt. are your 326 heads 4bbl heads or 2bbl? what are your cam specs anyway? do you think it would be hard to impossible to get 326 4bbl heads? thx
