I don't know about that, I'd put money on a 406 before I'd put money on a 396 built similarly. Just because the block is bigger doesn't make the car faster, thats just silly. Sure, a stock set of bigblock heads are nicer than the stock smallblock heads, but if you're goign to put the money into the motor anyway, the smallblock is the way to go, way more bang for your buck. Weight transfer is also better with the 406. Make no mistake, if you want aftermarket parts, you'll make more power for fewer dollars with the 406.
I don't understand why people keep preaching "yeah but bigblocks make more torque! it comes on like instantly!" No, they don't. The only reason it seems like they do is because they have more cubes. If you compair a 350 SBC to a 454, sure, you're goign to notice big torque with the 454. Cubes = Torque. Will you notice that between the 406 and the 396? Maybe. You might notice the 406 has better low end (more due to the better port design than the 10 cubes). That said, if I had a 396 I'd see who was willing to take it off my hands, and for how much. If I couldn't get a really sweet deal that would put me into a nice built smallblock with more power and some extra cash, I woudl keep it. None of what I've said above says that the 396 isn't a good motor. I think they're very good motors, but technology dates them quite a bit these days. If you have one and can't get a good deal for it, run it and be happy! K |
go big every other guy has a small block
dont be the norm.
thats because most guys see the value of having a smallblock. For me, i want the most bang i can get for my small amount of bucks. Bigblocks promote poor handling too. If you're into spending money just so other people can think what you've got is cool, whatever, but I build my cars for me.
K |
yes, BBC's look cooler. In aftermarket you're not going to make more power with a 402 than a 406. You'll lose, every time. With my 406, I've got less weight and my aftermarket heads will breathe just as well. In fact, there have been quite a few complaints from the performance community about stock BBC heads. Big ports don't = big power and good drivability. a 300cc port is going to be a dog on the street in a mild motor, I don't care if you do have 402 or even 454 cubes you're going to lose at the line-
K |
If you know how to build an engine, you CAN run 300+cc ports on a street/strip engine. Not that hard, if you know what you are doing. |
Oh and btw, yeah I think you're right, I'd probably keep the 396 too in most cases, but not if somebody was willing to give me a pretty penny for it! K Last edited by killerformula; 03-17-2005 at 08:08 PM. |
I would have to say that with aftermarket parts, the big block would be the superior motor for the money. If you compare a small block 472 to a big block 632, the big block is going to walk all over it, and really not cost too much more relative to the cost of the motors. What is another $2000 when you are already spending $12000-$15000 on a motor if one is going to make way more hp.
Adam |
I read in one of my Super chevy mags. They did a big block vs. small block test. They actually changed the engines out into the same car, a 70 Nova Each engine had similar components the small block was stroked out to 427 and the big block was a 502.The big block was cheaper to build by almost 500.00 and was nearly a second faster in the 1/4. Im a small block man I can barely afford to build a 383. But this is what I read!
bigger is better
i said it before and ill say it again
to quote my boyzz ZZ TOP " been around the block a time or two i found out only the best will do" NOTHING REPLACES DISPLACEMENT GOOD LUCK slowride66 (take it easy)
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
COOOL. K |
What is the deal with peopl that they feel they have to be different than everyone else to be cool? Who cares? Go with what makes sense. If you want a lighter weight engine build a 400. If you want more power build a big block. 396s are worthless, and so are 283s. Why waste the money? Build the biggest engine in the engine family. |
