big block or small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2003, 10:59 AM
Question big block or small block chevy
I was curious what everyone thought on the big vs. small debate . I have a 69 nova that has the mounting for a big block already . However some say put a small block in this car . I already do have a virgin 396 block out of a chevelle I was considering building . Also does anyone know the approximate weight of my car complete . Thanks for any suggestions.
Old 01-12-2003, 11:17 AM
project69ss's Avatar
Post
From 1969 chassis service manual.
"Curb weight approximately 2920 lbs.4 door sedan with L-4 engine:3050 lbs.with L-6 engine;3175 lbs. with V-8 engine.Vehicle dimensions Nova.
Old 01-12-2003, 01:10 PM
Post
Dude, Stick with a small bock several reasons.
PARTS WAY WAY WAY cheaper
They get as much respect as a big block if build correctly and Small blocks are lighter
did this help?!
chris
Old 01-12-2003, 01:37 PM
Post
They are cheaper to build and yes you can make up to the same amount of hp , but what about the instant torque with building a big block and with the nova i am not to worried about weight and is a 369 a good choice for a big block or do you get the bigger cubes with a 454 or the troublesome 427
Old 01-12-2003, 01:38 PM
Post
I mean 396 must have other things on my mind
Old 01-12-2003, 01:41 PM
Post
A bad running Big Block can out run a good running Small Block.A bad running Small Block cant out run a good running Big Block. Something to consider
Old 01-12-2003, 02:47 PM
ztoy's Avatar
speed freak
Post
Well, $ for $ the small block wins hands down. No way can you spend equal amounts on a bb as compared to a sb and , properly built, compete equally. As far as torque, thats one of the things that makes a sb so desirable is its low end (torque) capabilities. Now if your pockets a deep, then spend away and have fun with a bb.
Old 01-12-2003, 02:51 PM
ztoy's Avatar
speed freak
Wink
are deep, sorry....
Old 01-12-2003, 03:03 PM
Post
Theres just something about a BIG BLOCK MAN
Old 01-12-2003, 03:22 PM
dion's Avatar
72 Chevy Cheyenne
Post
For a daily driver I'd stick with the small block. For the weekend *** kicker, big block!
Old 01-12-2003, 04:08 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Post
If you have the 396 already, GO 4 IT!
You just cant beat the tourque of a big block. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-12-2003, 04:12 PM
Post
Nice truck dion,Always wanted one.
69YENKONOVA if It's a true yenko don't you want to go Big Block?put a s.b.c.in my camaro and 2 years later I am thinking on going to a B.B.(A.$.A.P.)Save some Money later and do the big block now.Just my opinion.
Old 01-12-2003, 04:16 PM
dmorris1200's Avatar
doesn't play well with others
Post
[quote]As far as torque, thats one of the things that makes a sb so desirable is its low end (torque) capabilities. <hr></blockquote>
Eh?????????
BIG BLOCK DUDE
[ January 12, 2003: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 01-12-2003, 05:46 PM
Post
I wish it were a yenko but it is a big block car and big blocks are it bit more amiable but what about a hood clearance , I dont want to butcher the hood and i would like to put on a victor jr intake which i hope will work well with 4.11 gears , th400 tranny and a 2500-3000 stall . This car will be a street machine that will hopefully run in the 12s when i take it to the track the odd time . Any suggestions please . I also have an original gm aluminium intake that i believe is off the L-78 , Weiand i believe worth keeping on or go with the victor jr .Thanks
Old 01-12-2003, 09:14 PM
Post
A bigblock is cheaper.I say build the 396.Dont listen to the bigblock cost me stories.You can make 550 horsepower out of any 396,even the lamest 2 bolt main oval port motor with a stock block,crank,and rods,and stock heads and even stock camshaft and stamped steel rockerarms and single roller timing chain.I built a totally reliable 396 that ran mid 11;s in a 3400# car on raw motor and mid 10's on nitrous all for under $3500.I used a stock 1969 low po 396,rebuilt with the stock crank,stock rods{with arp bolts] and stock replacemnt 396/375 horsepower pistons.I ran the stock oval port heads with the stock 30 year old small valves,I just added a 3 angle valve job and a bowl blend to the ports.I ran a stock oil pump and pan,a stock single roller timing chain,a stock 427 L88 camshaft{kinda big but it worked,I could have ran smaller},stock replacement pushrods and stamped steel rockers,with a dual plane weiand intake and 850 double pumper carb,drop in HEI performance distributor,an 1 3/4" cheapie headers.Now to do that with a smallblock would normally require aftermarket heads,a fairly radical cam,a stout bottom end,and a few more rpm's then the 396 would need to run.The entire engine minus the carb and nitrous was under $3500,and I couldnt kill it.I sold it to a guy who put it in a big pulling truck and it is still running today.Good luck.
