Big block or Small block...That is the question.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2011, 04:50 PM
Hey fellas im pretty new here and i saw some real interesting conversations and i had to join!
so here's the thought.... im goin to get a 53 chevy c/10 fleetside with a 350 in there... it runs enough to get home.... i have a 350 4bolt/2piece rear main std bore long block from an 88/89 fbody... there is also a 454/th400 std bore on craigslist for 250!!!! im willing to do a ground up build on either motors.... what should i go for??? i wont be driving it daily, and wont be hauling anything but maybe a motorcycle every once and a while..... im wanting to go for a resto mod build on the whole truck in the long run..... what do you think???
Old 05-19-2011, 05:52 PM
Wiki Edits: 31
'53 Chevy 1/2 ton is not a C10 it is a 3100. BB's are cool but you would need to change a lot to get it to work. Trans/ radaitor as well as springs for the extra weight and exhaust/ steering box complications.. Build a stout SBC
Old 05-19-2011, 07:07 PM
I am a big block fan and as far as difficulties,it's as broad as it is long in my opinion. I just stuffed one in a 55 Chevy.As far as the transmissions; any that will bolt up to a small block will bolt to the big block.For $250.00 bucks I'd say that would put you off to a good start on putting together a nice truck. Keep us posted,
400 small block question HammerGVette Engine 16 12-06-2007 07:33 PM
400 small block question 400smb_s10 Engine 5 03-28-2007 12:43 PM
400 Small Block Question 400smb_s10 Engine 10 03-20-2007 06:42 AM
400 Small Block Question hunter258215 Engine 4 06-28-2005 02:39 PM
400 small block question cub Engine 2 04-26-2004 09:29 PM
