big block spark plug help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 08:11 PM
I have a new 468 big block in a 1956 chevy. Carb, Holley 750. Ignition, HEI.
Have been running same set of AC R44N spark plugs all fall and winter with no problems.
All of a sudden last week, I am gas fouling plugs. I replaced the plugs with new R44N and they started fouling within 10 miles. The tailpipes are black and sooty.
What could cause the problem? Choke is working properly. Air filter is new.
I haven't messed with the carburetor or timing. Could carburetor need adjustment? Power valve bad, if so how do I know? Could spark be weak, if so how to know?
Should I try a hotter plug before messing with carb, if so what plug? Before plugs start fouling it runs like a scalded dog.
thanks boys for the help.
Old 03-31-2007, 08:25 PM
BOBCRMAN@aol.com's Avatar
Sounds like power valve gone.
Old 04-01-2007, 06:47 AM
bondo's Avatar
It's running Rich,.......
Why would you Change to Different Sparkplugs,..??..??
When you're dealing with a Fuel Delivery Issue,..??..??......
If your Clutch was Bad, Would you Change the Tires,..??..??.......
Old 04-01-2007, 10:36 AM
Bondo:
My thought was that possibly the plug is not hot enough to burn the summer blend of gasoline. How do you confirm that the problem is with the power valve. How hard is it to change the PV.
jt
Old 04-01-2007, 11:10 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
1.)
Holley ... power valves
If you have a carburetor older than 1992 (or you have experienced
an extreme backfire) and expect a blown power valve,
use this simple test. TEST: At idle turn your idle mixture screws
(found on the side of the metering block) all the way in. If your
engine dies the power valve is not blown.
2.)
4150 / 4160 series exploded view.
It's item #121 in this exploded view, right in front of the main carb body. You'll need a fresh pair of front bowl and metering plate gaskets at the very least. Holley's are a pretty simple design. About the hardest thing is making sure that you get the transfer-tube (if equipped) o-rings installed properly. Use a little smear of vaseline on them.
You mentioned "750" ... is it a List# 3310 with center-hung, dual feed float bowls? If so ... you're laughing ... easy. Try to get a 2-stage replacement power valve as well.
What spark plug should I run??? Ratoflic Engine 6 05-25-2008 08:18 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
Spark Plug wire looms and Ram Horn exhaust mainfolds Jag Daddy Engine 6 07-19-2005 09:13 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
