Welp, we have a nice snow day here and so had some time on my hands to poke around in this old thread. Nearly 8 years old! Wow. A lot of these older threads are great because they address some of the more basic questions of hotrodding like "big vs small block" "Ford vs Chevy" "Holley vs Edelbrock" etc.
Anyway its an interesting read. Not sure if its full of great information, but at least entertaining! Back on page 2, and probably 7 years ago, somebody posted this: Quote:
As you go upwards in torque and horsepower numbers, you need vastly more rigid parts, better engineered heads, forced induction or the like. With relatively stock, off-the-shelf components, obviously you can get into the 5 and 600 range with a big block more reliably and probably more cheaply than with a small block. Although its not the target of this thread, it also overlooks the fact that there are a mountain of reasons to choose to build a smallblock or a bigblock rather than just dollars per horse. Just a thought... K |
I totally agree that $/HP is a poor comparison or yard stick.
It make more sense to use that type thing when comparing modifications or bolt-ons that are for increasing the power on an engine that's already together. The car rags are great at doing a $150 mod (CC just did this very thing) to gain less than 1 HP. They swapped carb bodies to make a 650 a 750, to gain something like .6 (as in 6/10) HP! It could have just as easily LOST .6 HP depending on the dyno, if they'd have made another pull... Not a very good return on the money spent. But to hear them tell it, all was just dandy- ProForm being an advertiser and all.
bugging me....
after reading the entire post.... i just had to make a post.
a few replies said that the added weight of a bbc wouldn't be worth it in a 3600lb car, and that a 383 could do better... (just making up numbers, don't hit me) 489 bbc - 600hp, 550lb/ft (aluminum heads - 600lbs) 383sbc - 500hp, 400lb/ft (aluminum heads - 500lbs) at the cost of 100 lbs, you are getting 20% more hp,, and 37.5% more tq 3600 + 500 = 4100lbs 3600 + 600 = 4200 lbs weight difference = 2.4%!!! so your saying that an added 2.4% in weight is not worth the extra 20% in hp?? do some math and figure that in mid to heavy car applications, a bbc is the OBVIOUS choice for getting it moving. just because the power to weight ratio of the motor alone is way off, doesn't mean anything for the whole combo. My vote goes to BBC. that is why i am putting a bbc in my 3000lb car. (but... if you are on a $2000 budget, then i guess you have no choice, or you REALLY care about gas mileage, than a bbc will be a bad choice. if you really want to go fast, BBC all the way!) |
bbc vs sbc
Thought i'd throw in my 2 cents. I have a 3600 lb car. I'm am currently running a 383 stroker. Chassis dyno at 350 hp 345 lb/ft torque to the tires. It has 373 gears and a 2800 rpm stall. The car is quick, not a rocket ship but quick. Well I went out and bought a 468 BBC. I'm going to install it in a few weeks. Computer dyno software puts it at 550 hp 586 lb/ft of torque + or - 2% at the crank. Just numbers anyway. Nothing radical just a nice grocery getter. In my opinion torque rules on the street. People are right about the cost factor. I'll let you know how it turns out in a couple of weeks. Hopefuly I won't be disappointed.
Big Block 454
What I would do is use the 454 BB and install higher compression pistons and Holley multipoint fuel injection with a tunnel ram or bug catcher its all up to you with 11.5 - 1 cr pistons and the tunnel ram fuel injection this motor depending on the stroke and heads you select could make any where from 600 to 900 horsepower
