Big Brake Kit For Mustang II - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2007, 01:38 PM
Sweet-34's Avatar
Lost In The 50's
I have a '34 Ford Coupe with a stock Mustang II front-end and Steel 15" Wheels. Can anyone recommend a Big Brake (11") Kit for my car? I need a kit that won't move the wheels out and is a complete bolt-on. I don't want to have to chase extra parts not included in the kit.
I want American made products if possible to still find in this day and age. All input good and bad appreciated.
Thanks~~~~~~~Ron
Old 10-21-2007, 03:12 PM
Wiki Edits: 49
You didn't say what bolt pattern your using but here's a couple examples available from Speedway Motors.
GM bolt pattern
Ford bolt pattern
Old 10-21-2007, 04:15 PM
prostreethotrods's Avatar
big brake kit for mustang II
hey ron...with the mustang spindle you can use a granada 11'' rotor and with a adapter disc brake plate, with a gm caliper...(monte carlo)...all can be found either on e-bay or at your local parts store...this would be the simplest form, there are other options as well
Old 10-31-2007, 04:43 PM
Sweet-34's Avatar
Lost In The 50's
Mustang II Kit
Ordered a Big Brake Kit from MP Brakes (advertisement says it will fit 15" wheels or larger) and won't move the wheels out. Guess what....they don't fit my 15" wheels. Calipers drag all around rim. They told me it was OK to grind off some of the caliper to make them fit. I started grinding but you can't grind enough off to make them fit. Still waiting for decision (plan B as they call it) as what they are going to do. This kit uses the Big GM Truck Calipers.
Are late model GM (metric) calipers smaller? MP told me, if I switch to a Metric Caliper Kit which they don't make....I would also have to change my Corvette Style (1" bore) Master Cylinder. I am totally confused as what to do. I need a kit that does not move the wheels out and calipers that will clear my 15" steel wheels.
All input greatly appreciated.~
Old 10-31-2007, 05:38 PM
hey..ron... the 82-87 camaro rotor or the 78-80 granada rotor 11 inches..will fit the mustang II spindles ,, with a 82-92 gm metric caliper(camaro).. will fit your application, and clear most 14 and definitley all 15 inch rims...heres a page to check out for the caliper adapter you will probably need for the caliper, the truck caliper is a bigger caliper and will not clear a 15 inch rim...you will have to switch over the calipers to the one mentioned above, there about $30 a piece, rotors vary but are pretty cheap as well....
hope this helps you...rog
Last edited by Deuce; 10-31-2007 at 09:15 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 10-31-2007, 06:57 PM
powerrodsmike's Avatar
Wiki Edits: 161
ECI and Brake Tech Solutions have that 11" kit with the large GM CAR calipers.. And those are the only 2 that I know of that DO NOT move the wheel out.. IIRC the granada rotor mentioned in the previous post moves the wheel out 1/4"
I believe the Speedway kits like Centerline mentioned move the wheels out as well.
The ECI and BTS kits have special hubs with separate rotors to keep the wheels in their proper place..
I know I just bought the MII kit from brake tech solutions to install on a customers 40 ford and it was a nice setup. all the hardware was there and it installed fine...I got it to fit inside a set of 14" American Racing Torque Thrust II wheels , so I know they will fit inside 15" wheels easily. I did have to get the wheels internally balanced, because the calipers would not clear the stick-on weights, but other than that, it worked fine.
Both BTS and ECI use domestic and Canadian made parts where ever possible.
Later, mikey
BE different....ACT normal.
Old 10-31-2007, 07:56 PM
MII Big Brake Kit
Sweet 34,
I recommend that you call Chassis Engineering at 319-643-2655 and ask for Jim or Denny. They will explain their kit the rotors, calibers etc that they use which has worked well for me. I'm using their kit on my 39 Chevy which consists of 11" Granada rotors. The set up has worked well for me and Jim and Denny are very nice and knowledgeable and are very willing to to answer any questions you have.
Old 10-31-2007, 11:14 PM
Chopt 48's Avatar
Ebay wise I've been watching these caliper brackets for a while and need to sell some stuff and break down and buy a set.
http://cgi.ebay.com/ebaymotors/ws/eB...054943690&rd=1
Forged, not cut out with a trace torch and welded up. And the price is more than friendly.
He also has the cross drilled 11 inch rotors in either bolt pattern.
http://cgi.ebay.com/ebaymotors/aw-cg...m=260176295102
All I know about them is what we read in the add.
The same outfit also shows some complete kits spindle out including the spindle.
Old 11-02-2007, 03:56 AM
streetrodderbn's Avatar
Certifiable Streetrodder
I did'nt catch the bolt-pattern for your car. If you use the front disc brake kits that use the granada rotor,they will move the wheel out, if you have the Chevy bolt pattern,and use the kits that use the early camaro rotor,it will not move the wheel out. I have used both kits with the generic corvette m.c. with no adverse problems. Here's another question,why are you changing from the mustang II brakes on a light car? I have repeatedly fixed customers brake woes with this setup (on a light car like yours) simply by changing the pads to a wagner gold semi metallic pad! The car will stop great,and you will only be out $40.00 and about 20 minutes work!!
Old 11-02-2007, 06:08 AM
AntnyL's Avatar
Rim design (backspacing, hoop inside diameter, etc.) all need to be taken into account before ordering brake components. Saying "will fit 15" wheels" doesn't mean anything, and I'm surprised they don't have a disclaimer about this. Although that's probably a good thing for your situation as it gives you an "out"! Wheels all have different designs, so I highly recommend sending all the wheel and clearance measurements to your vendor before ordering anything else.
Wheel Vintiques has a handy diagram to fill out when ordering their wheels, which can be used to help your brake vendor select equipment that will fit your application. If you want a copy, go to their site: http://www.wheelvintiques.com/shopsi...tml/index.html, click on the Products/Prices tab, then go to the bottom and click on the Wheel Fitment tab. A PDF file will open which is a diagram showing the critical wheel dimensions you'll need.
An alternative is to keep the brake parts that you have, and order a new set of wheels that fit what you have.
Hope this helps.
Antny
Old 11-02-2007, 08:17 AM
Wiki Edits: 161
Antny
It means a little more than that, as most of these brake setups are based on parts that are of a relativly stock configuration...Most aftermarket wheels are made to fit stock configurations.. I don't see too many clearance issues with those type of kits unless the manufacturer starts mixing up some weird parts...Like the big truck calipers that come with the kit that sweet34 got.
Bear brakes has a really neat downloadable template with a scale on it so you can print out the paper, glue it to a peice of cardboard, and when you cut out around the lines, you get a perfect profile of the disc, caliper and hub...stick it inside your rim and it centers itself and you get a true view of the clearances..
Here is a link to the template for Baers track system for a MII, just to show you an example.
http://www.baer.com/technical/templates/files/D082H.PDF
It is too bad all of the manufacturers don't do this.
Later, mikey
Old 11-02-2007, 10:02 AM
AntnyL's Avatar
That's cool.......if you are using Baer brakes. Their recommended minimum clearance of 1/10 of an inch is too scary for me. I used 1/2-inch as a minimum to be safe.
I agree that all manufacturers should offer these templates to take the guesswork/errors out of this.
Antny
Old 11-02-2007, 10:18 AM
Wiki Edits: 161
I only used that as an example to show what the manufacturers should do.
You are right, in that if you start pieceing up a system from individual components, that you'd be better off getting your brakes together then ordering the rims. (aren't the brakes just a bit more important than the rims? Judging by all of the cars and trucks I see with 20" or dubs and tiny little brakes, it doesn't seem so)
What sweet34 wants to do isn't all that hard. Why MP uses truck calipers is beyond me. (if they are in fact truck calipers, early GM midsize calipers would be my guess) . He should have sent the kit back as soon as it didn't fit instead of grinding calipers and making them his.
Later, mikey
Old 11-02-2007, 01:38 PM
AntnyL's Avatar
I agree 100%; brakes are more important than wheels! Start with the brakes, THEN order the wheels to fit.
Antny
Old 11-03-2007, 12:49 AM
bentwings's Avatar
bentwings
Streetrodderbn,
You picked my curiosity here. I have a 41 Willys and much to my dismay the wheels are very close tothe fenders.
So if I read this right, I can replace my Granada rotors with early Camaro rotors and the wheels will be moved in some amount.
Now I have dual bolt pattern wheels so I think I'm good there, I have 15 wheels with a shallow offset so I think that is good too , now the question, Are the Camaro rotors 11 inch?? and I assume that the Metric calipers will work as is. In other words the rotor hat stays inthe same position relative to the caliper but the bearing hub is slightly offset to compensate. How much width will I lose per side??? 1/2-3/4 inch??
I already have a 1" Corvette MC and 7" booster, residual valves and adj proportioning valve.
Mustang II Kit Failure trees Suspension - Brakes - Steering 108 07-31-2011 01:45 PM
Where can I fnd a disc brake kit for jaguar rear end Larry Tyner Suspension - Brakes - Steering 8 01-08-2010 01:50 PM
Disc brake kit? Bo_Jangles Suspension - Brakes - Steering 0 06-25-2003 06:22 PM
Brake Booster kit for 57 Chevy JoeS Suspension - Brakes - Steering 1 03-09-2003 10:57 AM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 08:36 AM
