Big Brakes on my S10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2007, 11:15 PM
Hi All,
I have a 1954 Chevy 5 window mounted on top of an 1982 Chevy S10 Frame.
The rear end is out of a 4x4 S10.
I want to go with bigger disk breaks in the front and I want to convert the drums in the back to Disk breaks also. I really don't want to go out and spend $1500 on after market kit.
I heard that I could take the 1998 S10 Blazer disk brakes and they will bolt up no problem. Has any one done this type of thing?
All suggestions are welcome.
Thanks everyone
--Stars Brother
Old 02-02-2007, 02:50 AM
runn141's Avatar
SB S10
Originally Posted by Stars54
Hi All,
Thanks everyone
--Stars Brother
yes i have, they will bolt up no problem, but mine was out of 2wd blazer 2000 model because the 4wd rear is 4inches wider but if your 54 model bed is wider you should be alright with 4wd.on the front im using stock but in JC Whitney they have factory replacement cross drilled rotors for s10s. im also using steel braided brake lines that helps alot.
Old 02-05-2007, 11:23 PM
1lowryd's Avatar
you can also use rear diskes off a 94 and up camaro.everything bolts on with no mods. only v8 camaros use disk rears.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Does the 76 Lincoln Continental come with 9" and disc Brakes Tri5Nerd Transmission - Rearend 8 08-23-2005 11:22 AM
