Big cam with low CR heads, what to expect? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2012, 08:41 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Hey guys, please tell me how this engine will be like:
30 over SBC 350
Stock dished pistons
Edelbrock Torker II manifold
Summit 234/234 @ .050, 292/292 adv. cam
Holley 600 cfm
custom headers
882 heads mildly ported
it's going in my dune buggy:
very light, dual seater, mid engine RWD
TH350
1.800 rpm stall
3.50 LSD toyota supra IRS
31 in tires
My main concern is the crappy 882 heads, for now I don't want to spend more money, I must live with them for awhile, I know the cam is way too big for the low CR this heads give, what can I expect from this mismatch? poor driveability?, very bad idle?, little low end torque? or all of the above?
Since the buggy is very light, just the esential parts to keep it togheter, I hope it won't matter much, I will change to better heads in the future, or sooner if I hit the lotto.
please tell me what you think.
Old 06-30-2012, 09:04 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
not a fan of the intake, never used one but I've never heard anything good about the single plane torker manifolds. since the wieght of the vehicle is very light this will help you quite a bit with the lack of compression and duration of the cam. I would imagine that the engine will want a decent amount of advance on the timing but with all you have and setting the timming a bit more advanced i think you will be okay.
Old 06-30-2012, 11:02 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I agree with My87Z. You'll need tons of ignition lead with a custom curve. At idle you'll have a difficult time setting fuel mixture and it will likely smell very rich.
When you get around to it, sounds like you need some ported 305 heads. The chambers are small to get your compression up, but the ports need work to handle that cam.
The torker intake is a terrible choice for that combo and it will make things more frustrating from a tuning standpoint. Find someone who actually needs or wants a Torker and trade them for their Performer or RPM.
Old 06-30-2012, 11:31 PM
Augusto's Avatar
I've seen several pics of of a plenumm divider installed in the torker manifold, seems pretty easy to do and see if it works.
so, the main problem seems to be the manifold not the 882 heads, right?
a performer manifold + 882 heads will work fine with the 292 cam?
how about the very low compression ratio? I tought that was the main problem.
Old 07-01-2012, 05:56 AM
Use around 25 degrees of timing at idle and 38 total. Then add 10 more with an adjustable vacuum advance.
You need more stall converter. A 3000 rpm 10 inch stall should be about right.
Use an RPM intake (regular, not the air gap).
882 heads are not very good. A good set of 64cc heads would be really wake up the engine. I would expect at least a 50hp gain with a head swap.
Low compression isn't you biggest problem. I would put the low stall converter as the biggest issue, then the poor flowing heads, then the intake, then finally the compression ratio.
Old 07-01-2012, 08:51 AM
Augusto's Avatar
what would it be like driving the buggy at slow corners on a tight windy road with a 3.000 rpm converter?
Does it need to rev up to 3.000 to start moving? or just fully engages at that speed?
I guess the millage would be quite low, but if I wanted good millage I would of used a geo engine instead.
Old 07-01-2012, 03:00 PM
my87Z's Avatar
^^^ got me laughing
I agree
Cam and heads too big? Landshark928 Engine 11 03-12-2010 06:38 AM
What to expect from advancng the cam Argess Engine 8 09-20-2009 01:52 PM
Be aware of Low Cost, Low Quality Aluminum Heads Larry3 Engine 17 04-21-2006 07:05 AM
What Vac would you expect w/this cam? LanceM Engine 2 09-15-2004 05:14 PM
cam.. is it to big for stock heads or ok? CurtisL Engine 2 11-01-2003 09:23 PM
