big help in crisis lol - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 10:18 PM
okay i just finished my build a 327 in a 75 nova. i just finished it and tried to start but have no power anywhere. i though fuse no big deal will put one in after work. no luck with it. i have a charged battery and even tried to jumpstart it and nothing no lights or anything. i have the power going down to starter and have a mini torgue gear reduction starter. i have a ground from battery to chasis and on same bolt have a ground going to starter. also had another connector going to spade connector from wire harness. what did i do wrong? i havent put a ground on the block anywhere. should i have to? i am amateaur to this and slearning day to day and the motor is a 327 out of a 67 vette if that helps anything. like i said no power anywhere. really want to to hear all probable casues please. thanks guys and happy turkey day
Old 11-25-2009, 10:34 PM
nova327
Well lets start at the battery. Big cable going down to the top stud on the starter solenoid. At that same stud there needs to be a ten gauge wire going up to the fuse panel. You have enough ground wires and cables I think you need the wire leading back to the fuse panel.
The purple wire down at the starter needs to be attached to the little stud nearest the block. This is the wire that causes the starter to crank when you turn the ignition switch to the start position. So if you want to crank the engine without using the key attach a three foot length of wire to the little stud where the purple wire is attached. Then touch the other end of that three foot long wire to the positive battery terminal. It will spark but the engine will crank. If by chance the engine starts be ready to disconnect the battery cable so the engine will stop if something goes wrong.
I hope this helps
Scholman
Old 11-25-2009, 10:41 PM
i thought the top stud was the neg? i am almost posi. i have the 10 gauge wire you wanted me to use. and would this cause no power?
Old 11-26-2009, 06:43 AM
sqzbox's Avatar
My pipes are my music
Should have a ground strap from the block to the firewall. I experianced a complete power failure this week on my truck and found the fuseable link on the firewall had broken. Without it, there was NO power to anything. Did a roadside temp fix by twisting it back together temporary to make it another 1 mi. to the parts store where I bought another link, Wala! fixed it!
Old 11-26-2009, 12:15 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
The ground wire on the starter are you using the starter mounting bolt to attach that wire .., just asking for clarity using a bolt on the bell housing would be a better spot
Is this just an engine swap and the car was running to begin with? Does the engine have the alternator ? The best suggestion I could offer is to get a test light from pep boys or auto whatever. Then you have to start see where the power is . Hard to make a reasonable guess from the post .
Old 11-27-2009, 09:14 AM
okay. i got it started. wheww a wire was lost in the swap and i fixed it. i fixed and she sounds mean. just a real radical idle. the only thing i have to do now is go thru and make it look good lol. i will post a pic in a little
Old 11-27-2009, 11:33 AM
sqzbox's Avatar
OK, SOOOooo.... What wire was it?
Old 11-30-2009, 08:54 AM
the wire that also connects to the hot post on the starter i thought i had it on. but a second look told me otherwise
Old 11-30-2009, 09:51 AM
sqzbox's Avatar
Well, guess I was close huh? right wire, wrong end !
Old 12-11-2009, 02:22 AM
84MonteCarloCS's Avatar
no power
i went out to start my 84 monte one morning and it cranked twice and then i lost all power i tried to jump it but still no lights or cranking power please help
Old 12-11-2009, 07:35 AM
sqzbox's Avatar
check the fuseable link to the starter.
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 08:23 AM
Big cars Wmarden Hotrodders' Lounge 16 09-12-2004 08:05 AM
engine too big? deuce_454 Engine 11 04-04-2003 02:46 AM
Big Mack Kevin45 Hotrodders' Lounge 0 12-08-2002 12:33 PM
big tires? cannedheat Body - Exterior 6 10-16-2002 12:35 AM
