BIG Horsepower RearEnd Setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 02:40 PM
Im curious what everyone thinks.
i have a 496cid running about 750hp and 700ft/lbs (street Car)
TH400 Built solid (5000stall) and a transbrake
Heres the question, I have a 12-bolt rearend, richmond gears(3.73) and a detroit truetrac LSD. it is necessary to do C-clip eliminators and aftermarket axles?
Old 04-25-2011, 03:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I wouldn't use stock axles, that's for sure. Need more splines as well, IMO. C-clip eliminators have gotten some bad press in the past, w/leaks and such- better to use Ford housing ends- but in any event it's a hell of a lot better to retain the wheel than to have it come out of the housing w/half an axle connected to it.
Bottom line is w/a transbrake, high stall TC, 'street car' weight and any kind of traction will be taxing a 12 bolt to it's limits. Use all the tricks of the trade available to you to strengthen it, including welding up the tubes 360 w nickle alloy filler.
Old 04-25-2011, 05:00 PM
Yes you need them. Mark Williams makes the parts you need.
Curious on a High Horsepower Stroker Setup ??? 421strokerguy Hotrodding Basics 19 03-29-2010 10:09 AM
Estimated horsepower for my setup?? brad1 Hotrodding Basics 1 04-07-2009 07:50 PM
Help me with my Rearend setup (handling/ride quality) LiftFlat Suspension - Brakes - Steering 8 03-05-2007 12:43 PM
Rearend Setup rossco Transmission - Rearend 5 02-08-2007 12:39 PM
Rearend vs. Horsepower reclusej Engine 4 01-17-2003 12:28 PM
