Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big low spot on the roof corner
Old 01-17-2013, 07:58 AM
MARTINSR MARTINSR is offline
It really needs a pull on the rear body to relieve the pressure. You can pull that little dent out but with the pressure that probably there in the back end of that car it may come back unless repaired properly.
Heating it up, you are asking for trouble. Do you have a shop you could go to and get the pull and maybe the work just started and you finish the filler work and primer and all?
The Following User Says Thank You to MARTINSR For This Useful Post:
dogwater (01-18-2013)
