Ignition Switch
[color=lightblue][size=3]Doc here
Here is one option, get a body hammer (the one with a sliding weight on it and a threaded sheetmetal screw at the front) and screw the body hammer all the way in the key slot, then give the hammer a good jerk backwards and the key cylinder SHOULD pop out. Just insert a slotted screw driver down the shaft where the cylinder came out and turn. BE ADVISED: If you do this method, and a COP pulls up along side and sees it, be prepared to be pulled over for a Felony Car Stop... Since this is the preferred method of car thieves... So be sure you have ID and the Paperwork! I would replace at the very first opportunity! I don't think there is any SAFE way to "Hotwire " That truck, as it is computer Controlled and relays on several things to operate when the IGN is on, So just jumping a wire to the coil probably won't get you running, and in fact might damage something else. So I would aviod that. You CAN get everything to work By just taking a heavy Jumper from any 12 volt source (Hot, Battery, not switched) To anything on the IGN or Acc Side of the fuse box buss , Everything will come on like you turned the key on, except for the starter (which can be started at the solenoid with a screw driver) , and the column will still be locked...But this is risky....you could overtax the fuse buss and burn things up especially if you try to run it...I would not advise it. Gee...How do I know this stuff?? And no, I've Never Ripped off a Car... Try the Body hammer first! Doc ========================= I want to die like my grandfather did, peacefully in his sleep. Not screaming in terror like his passengers.[/color][/size]
Aftermarket Solutions Electronic & Electrical Innovations |
I'm with Doc, I own the same truck and had to do the same thing. I drilled mine out with a large drill bit. That spade bit won't work. It beats the hell out of you. You just have to break the lock loose so you can turn it then pull it out and replace.
