Big Valves in #46 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2010, 10:39 AM
UngerMarkus's Avatar
TuckīnīRoller
Big Valves in #46
Hi guys!
Iīd like to put big valves (2.11/1.77) in my #46 Pontiac heads. I already got the intake valves, but Iīm not sure wich exhaust valves to take. Does anybody have an idea?
Thanks
Markus
Old 02-17-2010, 11:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by UngerMarkus
Hi guys!
Thanks
Markus
Are these the good '74 GTO 350 #46 heads, or the pressed stud 2-bbl. heads?
If you want 1.77's, go w/the same valve that Pontiac used in all their D-port heads that year.
BTW, the 350 GTO #46 heads w/screw-in studs have 45 degree seats. You will want to verify the angle of the intake seats of your heads. The Pontiac 2.11 valves- if OEM design/type, will have a 30 degree angle.
Old 02-17-2010, 11:17 AM
TuckīnīRoller
Iīve got fully ported 2bbl heads.
According to the measurements at rockauto.com the bigger valves are slightly longer then the small ones. Is that a problem?
Old 02-17-2010, 11:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not as long as you are using an adjustable valve train AND correctly match the p-rod legnth to get correct valve train geometry- something that you'd be checking, anyway- if you're changing cams, decking the heads/block, changing compressed thickness of the head gasket, etc.
You will want to check and adjust the valve spring installed height, if needed, as well.
Old 02-18-2010, 12:26 PM
TuckīnīRoller
Well, the bigger valve is 0.009'' (= 0.228mm) longer than the stock valve. Do you think a hydraulic lifter will compensate that? Or do i have to go for poly-locks?
Old 02-18-2010, 01:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I can't positively say one way or the other, to be honest.
The 0.009" by itself will not be enough to cause a problem- provided you aren't at the very top or bottom of the lifter's plunger travel.
I'd try it first w/the stock nuts and bottle neck studs. If they're a no-go, go w/locking nuts.
There have been cases where polylocs haven't had very much engagement on the b/n stud, so see what yours look like when you get to that stage. If you think there's gonna be a prob, you can use new, "regular" rocker arm lock nuts. There is a chance that you'll need hardened spacer washers under the nut to get the correct preload, but if this is the case w/the lock nuts, hopefully the polylocs will have enough engagement.
The better way to go about this, is to install good, straight wall studs and polylocs. There was a thread here just yesterday that had a guy breaking his stock studs, so there is a possibility of it happening.
Old 02-18-2010, 01:47 PM
.009 isn't going to cause a problem as when a valve job is done they machine off .002-005 on the tip , you can have the tips machined/ground to remove the excess if you want without any problems ,just make sure your spring installed heights are not affected and the tip isn't below the retainer
Old 02-18-2010, 02:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To see what's going to be needed will take a mock up or three. The spring IH will be the same before/after the tip is ground. Just be sure it needs to be ground in the first place.
Unger- Did you see if the 2.11" valves are 30 degree seats or not? And what is the seat angle of your 46 heads? Anyway, just be sure the machinist is up to speed on the deal.
I don't know what I'd prefer on a 350 Pontiac- 45 or 30.
Old 02-18-2010, 03:23 PM
on the 350's the 30 degree works better it allows flow to start at a lower lift ,the shrouding will take place in the head , just make sure you have clearance on the valve heads at the edge of the bore , seen too many valves bent this way . with the 2.11's on a 350 you can get away with using the 1.66 exhausts it keeps the flow speeds up , my street motors liked it better with the smaller exhaust valves with a header made more torque you could see on a dyno and in the butt dyno too .
Old 02-18-2010, 03:55 PM
TuckīnīRoller
thanks for your fast replies! I don't have 350 heads. They came on my 1969 400cui 2bbl engine. Now it's got a performer intake, a mild cam (214/224 @ .500" 112^ lsa) and headers.
I'm gonna check the seat angle tomorrow.
Old 02-18-2010, 04:28 PM
if its a 400 ,30 degree seat angles work great and the bigger exhaust is ok . .
Old 02-18-2010, 05:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unger, if your heads came on a 400 originally, they will be 30 degree seats on the intakes.
The 350ci GTO heads were the ones w/45 degree seats, I believe- so your valves should be fine- as long as they clear the bore.
Old 02-19-2010, 05:08 AM
TuckīnīRoller
Great!
Well, back in the days there were big valve heads available for that engine, so I think this shouldnīt cause any problems.
Thank you very much!
Big Block Exhaust Question RamAirZ Engine 2 07-22-2009 05:03 PM
big block trouble steinwinter454 General Rodding Tech 2 12-07-2008 08:43 PM
ideas for big block truck build boatanchors Engine 12 11-16-2008 08:20 PM
Big cars Wmarden Hotrodders' Lounge 16 09-12-2004 09:05 AM
Big Mack Kevin45 Hotrodders' Lounge 0 12-08-2002 01:33 PM
