big windsucker - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2002, 06:20 PM
Smile big windsucker
once upon a time i posted a question[light years and another galaxy ago] the problem was that my holley 750 vacumn sec. carb. would stay at wide open throttle AFTER ! i had let off the throttle.some of you out offered many good suggestions re: the problem.well i finally figured it out and always like to report the solution!seems the accelerator pump adjustment was so out of whack it was putting more pressure on th nylon bearing cam than the spring could overcome,two turns and voila!,all is well.hi guys !see ya ! jimm
