Bigger Brakes! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2007, 12:10 PM
Last journal entry: My older projects
Bigger Brakes!
Hi.
My project is a ´39 ford coupé, 1989 corvette suspension and a
2004 srt-10 viper engine.
I´m sure that I will have some problems to get the engine in the car
but it can be solved.
My question is.
Do you think I should swap to bigger and better brakes or is the
Corvettes original brakes good enouth?
Poor english, sorry I´m Swedish...
Regards Martin
Old 02-27-2007, 12:29 PM
327NUT's Avatar
Howdy...you're English is just fine, for the sake of a lot of money and extra fabrication I would stick with the Corvette brakes. You can always upgrade them to slotted or drilled types at a later date if needed. Probably would'nt hurt to have the rotors turned now and install a good set of carbon metallic pads......also try to keep the speed under 150 or so!!! Thats going to be an awfully tight fit in that 39's engine bay, ......good luck.
Old 02-27-2007, 12:53 PM
Thanks for your reply 327.
I will go to LA on friday to pick up the engine and to arrange the shipping
so if you know were to find brakeparts it would help. You see. If I buy the parts in sweden I will probably have to pay the dubble.
You are so right about the engine, after some measurments I have found out that I need to move the firewall atleast 6 inch back, reshape the inner fenders and move the sofa to the trunk(almost) and probably a lot of other
mods but what the heck. Isn´t it worth it!!
Thanks!
Old 02-27-2007, 01:13 PM
327NUT's Avatar
I did a little checking, L.A. is a BIG area so I just looked up "Autozone". They have their best carbon metallic pads for the Corvette listed as "PFC-Z rated" fronts are part# 413Z @ $69.99 and rears are part# 412Z @ $59.99, they come with a 2 yr. warranty. I know they are good pads because I have them on my '02 F-250 Powerstroke diesel 4X4 (not the Z rated) and I pull a 28 ft. gooseneck horse trailer, no problems. Just look in the yellow pages where you are staying, they may have to order them but that should'nt be a problem. And just tell the guy you want brakes for an 89 Corvette, if you mention you're putting them in a '39 Ford he may vapor lock on you. good luck....Dave
Old 02-27-2007, 01:19 PM
Thanks a lot for your help Dave.
I will run to Autozone on monday.
Bigger brakes for a Ford 8 inch junkyardjeff Transmission - Rearend 2 11-16-2006 09:23 PM
Porsche Bigger brakes and suspension Cocacolakidd Suspension - Brakes - Steering 3 12-22-2005 03:01 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
do I need bigger brakes? rustie Suspension - Brakes - Steering 1 03-06-2004 09:41 PM
