Bigger brakes for a Ford 8 inch - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2006, 07:19 PM
junkyardjeff's Avatar
I put a maverick 8 inch rear in my 55 sunliner and I had to pull the axles to replace the bearings and I noticed the maverick brakes might be a little small for that size of car,does anyone know of a larger brake assembly I can put on the maverick rear. I was thinking about 68/69 and 70/71 fairlane or torino brakes and since I had new bearings pressed on I dont want to change the axles if possible. Jeff
Old 11-16-2006, 08:40 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Try looking at the brakes off the back of a 1971-73 Mustang that has a 9" rearend.
Old 11-16-2006, 09:23 PM
As a general rule ... as long as the donor Ford vehicle has the same housing ends ... you can change the backing plates ...
I have done this many times on the 57 Ford rear ends I like to use. I usually use 65 - 66 Ford Galaxies backing plates and drums. They are 11X2
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 05:39 AM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
