Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bigger power steering pump pulley?
Old 03-06-2013, 07:46 PM
46streetrod 46streetrod is offline
If your steering is feeling to loose they make flow control valve that decreases the flow of the GM pump for around $28. We use these for cars with GM pumps on MII racks.It drop the flow 1 Gallon per minute. For pressure problems there is a shim kit that goes in behind the valve on the pump,but it is trial and error.I would try the flow valve first this works 90% of the time.
