Bigger tire size decrease acceleration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2004, 08:51 PM
Meka's Avatar
Hey, Not to long ago I had the rear tires on my car replaced with a little bit taller/wider of a tire. Scence then it seems like my car has not had as not as good acceleration from a stand still. I was wondering if im going crazy or it this bigger tire selection in back has caused this.
Thanks
Old 04-12-2004, 08:53 PM
Rhansen's Avatar
Footbraker
You're right. The taller tire slightly increases the effective gear ratio.
Old 04-13-2004, 05:32 PM
tires
wow if it is that noticable on a street car you must of really went with a bigger tire or have some really numerically low gears
Jesse
Old 04-15-2004, 08:28 PM
69elcaminoss's Avatar
I went from a 24" tall tire to a 28" inch tire and yes, without a doubt raised the gear ratio and also of course hurting acceleration.
Think about it, you have a bigger tire that will rotate less per distance traveled. Think about it in big terms, what if the tire was 10 feet tall, it would take a while to make a full revolution thereby raising your final gear ratio.
Old 04-16-2004, 12:15 AM
Sandflea427SS's Avatar
Anything with a throttle
My freeway gear cars are the 427 Impala and the Monte. 3.07s for the Imp and 3.08s for the Monte. And, I have 275/60s on the rear. The other extreme was the 69 396 Chevelle I had with 4.56s in the rear. The car had 26 inch tall tires on it when I bought it....Jeez.....I drove it home from Ghettojets town doing 45 the whole way.....ughh.....I later put 275/60s on, but it didn't help much. That car was great in town....Even though I only used 2nd and 4th in the Muncie!
The other Chevelle has 3.31s.... Both 79 Z-28s had 3.42s...
The 67 Camaro I had was an open who knows what? and later a buddy and I put 4.11s in it!
Oh...forgot about the 69 Chivy C-20 I used to own....4.88s......
