Is this (bigger) valve sitting right afte the new seats and valve job? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2005, 07:33 PM
Hey guys, I am still at it with this ford 3.8 V6 out of the tbird supercoupe, and have a question.
I got my set of heads back form the machine shop today, and I am a little worried about how this valve is sitting... I used 1.625 ex valves,and stuck with stock intake valves.
The valve is "thicker" than the stock valves, it is a Ferrea valve just FYI.
Am I gonna have to worry about piston to valve clearance??
I am also confused on how may cuts there are.
This is spose to be a 3 angle VJ, but all I see is two cuts on either surface. Does 3 angle mean 3 angles, or 3 cuts???
Take a look at the pics, and see what you think about how this valve sits, and how far towrds the edge it is.
Is something wrong here, should I carry them back up there and have him "sink" the vlave more?
Thanks guys!
ID:	8242   Click image for larger version
ID:	8243   Click image for larger version
Old 12-09-2005, 07:34 PM
one more pic...
Old 12-09-2005, 07:48 PM
Jmark's Avatar
From my limited experience, the exhaust valves are usually thicker than the intakes. My heads looked just like yours when I put in all new valves. As far as the "3 angle" valve job, I believe it only applies to the seat and seat area, not the valve. The 3 angles on the seat are to aid the flow into the runner. The valve only seats on one area. ( Hope i'm right on all of this! LOL i'm not a machinist.)
Mark
Old 12-09-2005, 08:11 PM
Bumpstick's Avatar
Hammer and a torch
From what I also know this is a normal apperance... The exhaust does have a thicker head so it will not "tulip" under the intense heat it has to survive...
Old 12-09-2005, 08:48 PM
Same here. Looks normal to me.
A 3 angle valve job is pretty standard. The seat area is cut at 45*. Then you use a 30* to cut the top angle and a 60* to cut the inside. By cutting the top and inside you set the seat angle thickness and location on the valve head. You can add a 15* and a 75* to taper the seat more...a 5 angle valve job. When you "lap" the valve in you are actualy confirming the seat width and location on the valve.
Old 12-09-2005, 08:53 PM
Jmark's Avatar
Cool! I was right! LOL
Old 12-09-2005, 11:13 PM
Just a reminder.....Dont forget to recheck that geometry. It will be different.
Old 12-10-2005, 12:05 AM
What is the process for lapping the valves?
Old 12-10-2005, 06:50 AM
BOBCRMAN@aol.com's Avatar
Forget lapping the valves.. On an aluminum head motor. The cold pattern you see is not even close to where the actual "running" seat will be. The exhaust valve runs at or near red hot (read expand) the aluminum head and the valve seat insert run much cooler.
As a novice there is a good chance of you screwing up a good valve job. If you MUST see where the cold seat is get a "Majik" marker. Ink up the seat, then insert valve and spin it against the seat with light pressure. Remove. You will see where seat edge contacts valve.
If you see only a knife edge line, don't worry, as most valve jobs are done with 1/2 degree interference fit and only the edge will show contact under light checking pressure.
The thicker exh valve margin should not be a problem unless you are using a long duration, high lift, aftermkt cam and the heads have been excessively shaved.
You did have these heads resurfaced didn't you??? They are famous for being warped or Brinnelled badly!!!
Old 12-10-2005, 10:12 AM
This is not a huge cam at all, 212/220 .531/.539, I also did have the heads surfaced.
Thanks all!
Old 12-10-2005, 10:49 AM
NAIRB's Avatar
That's a fair amount of valve lift. You will want to check valve to piston clearance anyway. You will want to check your stem height, this will tell the story if the seats are cut properly for the valves that you have. I'm not sure what the factory stem height is on a 3.8 Ford, but they should all be equal. Is this converted to a fully adjustable rocker arm?
Old 12-10-2005, 05:30 PM
I will have to check the clearance just incase, but I'm told that other guys running the SBC valves running even more lift don;t have probelms. But I guess I'll check just in case. They were suppose to deck the block to zero hight, so I guess I'll hv to check. What is a safe piston to valve clearance? How would I measure that? Do I do the putty on the piston thing, then see how deep it is? I don't know how accurate that would be...
The rocker arms are stockers, non-adjustable, but can't they be shimmed up if necessary right?
Thanks!
Old 12-10-2005, 05:35 PM
I don't quite get what you're saying, are you saying aluminum heads run igher temps in comparison with iron heads?
I don't see how that would make any difference for the valve seats...
Old 12-10-2005, 06:22 PM
coldknock's Avatar
The aluminum heads expand and contract moreso than iron heads do, it will change the shape of the seat when the engine is running. That's why checking the exhaust valveseat contact area is almost pointless as it will change a good deal after the engine is running and up to temperature.
As for the valve-to-piston clearance, It's not only the size of the valve that makes checking the clearance necessary, it's the increased lift from the new camshaft along with zero decking the block and milling the heads. All three of those conspire to decrease you valve clearance a great deal, it's a good idea to verify there's enough space between the valve and piston when that many changes are made that affect that particular specification.
Larry
Old 12-10-2005, 06:46 PM
But the seat is not aluminum, so how would that make a differnce on the seat?
And what is a safe piston to valve clearance to run?
I am told, even with a .580 lift cam, their is no issue, but I'll check it anyways...
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 12:19 AM
Is there a way to identify hardened exhaust seats? 357ford Engine 5 10-28-2004 09:29 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Cutting bigger valve seats fiscus Engine 2 04-07-2004 02:20 PM
3 angle valve job or seats jeff germano Engine 8 10-23-2002 12:25 PM
