Biggest 120V air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 08:58 PM
ComingApart's Avatar
I need to find the highest CFM compressor I can that will operate at 120VAC. 15amp
Something that I can do some light sandblasting with.
I Know thats kind of a tall order, so I'm turning to you guys here.
Thanks
Old 10-05-2006, 03:06 PM
shopratwoody's Avatar
air compressor
If you can find an older one out of a shop, the type that the motor runs
at 1750 rpm that would be the best. They have single phase 120 5 HP
that are about 14-18 CFM. I have an older Champion that 14-15. Mine is
3 ph but my friend has one that's single ph 120. The 1750 motors are a much
quieter compressor that these new junkers. Good Luck
Ron
Old 10-05-2006, 05:34 PM
110 volt compressors are limited by the AMP draw and you will not find one anywhere near 5 HP. Because of the power limit the biggest one you can find will have a low CFM rating that would be suitable only for spot blasting and small jobs. If you do try to get by with a 110 volt outfit then you should use a small pressure type blaster unit with a small tip (3/32") instead of a suction type. It's just laws of physics, it takes a lot of power to produce a lot of CFM at a usable pressure and a 110 volt circuit will not supply that much power.
Old 10-05-2006, 07:12 PM
Wiki Edits: 31
as long as you have 2 on 2 seperate plugs running 2 seperate breakers, couldn't 2 heavy duty cables ( 2/12 Romex ) be plugged into 2 outlets and then wired as a 220v circut? then run a 220v compressor? I only do 110v wiring but have always wondered this.
Old 10-05-2006, 09:48 PM
110 compressor
sorry bout the misinformation on the compressor, I was thinking of single phase versas 3 ph. You can have a single phase 220 5hp motor, not 110.
What was I think'n
Ron
Old 10-06-2006, 05:58 AM
Matt, Got me a little confused there with exactly what you mean but if you are talking about using two 110 volt units hooked together (air lines) then yes that would work as long as they are on two SEPARATE circuits and SEPARATE BREAKERS. Even with two 110 volt outfits you would be pushing it to do much sandblasting but it would work if someone is limited to only 110 volts.
Comingapart, When I said you will not find one anywhere near 5HP I meant real HP and not that phony "peak" or "maximum developed" HP nonsense. If you look around you can probably still find one of those ridiculous things with that garbage printed on it but DON'T fall for that! Those outfits lost a class action law suit and was ordered by the courts to stop inflating the power ratings but some of them can still be found and even the newer ones are suspect IMO.
Old 10-06-2006, 07:52 AM
If you're saying what I think you're saying it would work as long as the 2 outlets were on different poles in the box. It would not be advisable though. If one breaker tripped and the other did not you could do damage to your motor. It would be much easier to put a 220v breaker in the box and run it the correct way.
Danny
Old 10-06-2006, 03:35 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Gonna need 10ga wire for a 30 amp 220 circuit
and 8ga for a 50 amp
Also need to check if the equipment or your elec codes require a neutral wire.
some do and some don't
need to also use a 2-pole circuit breaker or fused disconnect box for this
2 hots and a ground (+neutral if required)
Also the plugs/outlets are different for 30 amp 3 wire/50amp 3 wire
30 amp 4 wire/50 amp 4 wire
Be safe with this---fires are no fun
Bryan
Old 10-06-2006, 03:40 PM
Wiki Edits: 31
Danny
yep that's what I was thinking, I was just wondering if it would work. Right now, I do what Old red said. 2 120v compressors plumbed into an air system. works decent enough for me.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 10:17 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 06:24 PM
