#1
biggest big block chevy engine displacment?
how far can you bore and stroke a 572 bbc to? whats the largest cubic inches i can get from an after market block?
Register now (free) or login to remove ads |
#2
Most GM Bowtie blocks can be bored to 4.630", and I have seen 4.750" stroke cranks fit, but be prepared to do a whole lot of rod clearancing. Most of the Mountain Motor IHRA style aftremarket Blocks, have a 5.000" bore center spacing that allows a much larger bore, 4.750" is pretty easy to obtain, and usually 800 cubic inch is normal in the P/S classes.
#4
I need to correct myself. Sonny Leonard currently has a 932 Cubic Inch GM style engine. It has a 5.300" bore spacing and has a 5.080" bore with a 5.750" Stroke for a mere $89,300 dollars. It has 2140 HP and 1475 Ft. lbs. of torque!
#5
Only $90,000! We should all go out and pick one up today at those bargain basement prices.
#6
Not to hi-jack the thread but what about a production 454 block....how many cubes can you get from one of those?
#8
A 572 is already bored and stroked about as far as you can go. Aftermarket blocks can easily go into the low 600s, but you'll be well into the $40,000 range to get it until you buy the block, custom pistons, crank, oil pan, timing chain, valvetrain components, and heads that will supply enough air. Not to mention the $10,000 on a tranny that will take the torque, $10,000 on a rear axle, a full cage that won't twist the car in half.... the list is endless. |
#9
It entirely depends on the block and how thick it is to start with. On a production 454 block (which were all short deck), I've seen 526 (60-over with 4.5 stroke) but it all depends on the block. Some can be safely overbored more, and some can be clearanced a bit more for a crank before hitting water. |
| Thread Tools | Search this Thread |
| Similar Threads for: "biggest big block chevy engine displacment?" | ||||
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 1968-1969 olds 455 engine is this good and how can i id | 1968olds455HO | Engine | 5 | 09-02-2009 11:53 AM |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Big Block Chevy Power Steering Brackets | fosterdl | Suspension - Brakes - Steering | 1 | 04-16-2009 09:04 PM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
