biggest shot of nitrous i can take? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2006, 06:29 PM
have 454 .30 trw forged pop ups. comp is between 10.5 - 11 to 1.
cast rods shot peened, magnu fluxed , beams ground downed, arp rod bolts.
cast crank 10/10 10 thousands end play, yea i know. king racing bearings. motor already making about 500 to 575 hp spinning to 6500 rpms
so what would be the best shot i could use , thinking about 150 to 200hp
shot.
Old 11-29-2006, 09:30 PM
150-200 shot shouldn't be a problem. However you'll need to retard the total timing about 8-10 degrees when you dump the nitrous to it. Cylinder pressure and temperature goes way up and the engine needs less timing. Be sure you DON'T use extended tip spark plugs with that much nitrous or you could get preignition then detonation. Put a fuel pressure gauge where you can see it when you dump the nitrous to it. Make DAMN sure your fuel pressure doesn't drop during your run. If the engine goes lean from lack of fuel you'll be building a new engine. Have fun.
Ron
454, Long Rods, and Nitrous, oh my 83Silverado Engine 1 03-31-2006 10:26 AM
Thinking about building a purpose built nitrous motor! Please critique leemoses Engine 22 06-19-2005 10:15 PM
Shot Peening - Interesting Read dbuff Engine 0 09-02-2004 01:43 PM
nitrous with high or low compression? brainsboy Engine 5 03-19-2004 06:23 PM
top shot nitrous systems cuda66 Engine 2 03-01-2003 07:24 PM
