biggest size tire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 09:52 AM
tombo615's Avatar
biggest size tire?
hey guys, i have a 69 cutlass with a 12 bolt chevy right now, and its about time i get a new set of wheels and tires. whats the biggest size tire I can go with? I've heard 275/60/15 and 275/50/15 from a few people..but is there anyway i would be able to fit a 295/65/15 or a 325/50/15 with the right backspacing?
Old 01-24-2006, 09:43 PM
TechnTool's Avatar
OldSchool MotorHead
That depends on the offset of the rims you are using. Pick the size tire you want, then look for a wheel that will makeit fit under the fenders. If there are no wheels available, then either flare the fender or shorten the axle.
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Tire size converter? RObs71Nova Suspension - Brakes - Steering 13 12-11-2004 01:33 PM
biggest rim and tire size for a 55 chevy vin171 Introduce Yourself 1 06-22-2004 07:30 PM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 05:38 PM
