Bigs Carbs...scammers! - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #31 (permalink)
Old 10-03-2008, 07:58 AM
OHD's Avatar
OHD OHD is offline
Did YOU custom order a color and supply every spec or just the color?
What was said, BY YOU, when you called to discuss the "issues" you have with the carb?
Did YOU drop the f bomb over and over and over?
Did YOU return the carb for corrections?
Do YOU blast each and everyone that disagrees with your "way" of doing business?
  #32 (permalink)
Old 10-03-2008, 08:02 AM
OHD's Avatar
OHD OHD is offline
Curious,
What are the specs on the engine in your tube frame, race car that has such a radical cam that it has no vacuum and requires a 650 CFM carb?
Like to understand this one...
  #33 (permalink)
Old 10-03-2008, 08:23 AM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by OHD
Curious,
It is not a 650, the proform part number that TRAILERKING shows is a 1050 CFM mechanical secondaries race series carb.
Go to the proform website and see for yourself.
I did some research, TRAILERKING could show his car and give a little info if he wants to get a little more respect here.
Later, mikey
BE different....ACT normal.
  #34 (permalink)
Old 10-03-2008, 08:26 AM
Curious,
Obviously you would already know all that info seeing that you are on the inside with Bigs and know all the details of the transaction. However it was likely left out in your conversations about the removal of the (2) 750's, tunnel ram, two stage foggers all to go to a single four barrel 1050/4150 config.
On a final note.
You sir, OHD, aka On H___y D___s are an act like/know it all/r____d.
By the way just to refresh you and Mr. Jesse's memory.
433ci Olds 13.2-1 comp.
head flo
int .800@330
exh .700@300
cam
int
.770@.050 @280
exh
.728@.050 @.288
.112 lc
60 deg o/l
1.7 rocker
gear 5.13
tire
33.5 33-16
wgt
2550lbs
trans brk rpm
6000
shift rpm
8500
  #35 (permalink)
Old 10-03-2008, 08:32 AM
Wiki Edits: 161
This thread is one post away from getting locked.
Any assumptions about mental states, ancestry, level of intelligence or any more digs at a person will do it.
By anyone
Mikey
  #36 (permalink)
Old 10-03-2008, 08:49 AM
Later, mikey
Here's a pic Mikey. Sorry about the assumptions.........I edited the post.
  #37 (permalink)
Old 10-03-2008, 08:54 AM
Wiki Edits: 161
Thanks Bernie.
That's the same car I saw when I was looking around last night..using the detective tools in my moderators toolkit .
What kind of times are you turning with that car?
Later, mikey
  #38 (permalink)
Old 10-03-2008, 09:21 AM
Later, mikey
Best so far was a 9.0_ @ 150._
  #39 (permalink)
Old 10-04-2008, 12:19 PM
Wiki Edits: 161
This thread has been split.
The posts that were sent to the dump are not conducive to getting a resolution between Bigs Carbs and Trailerking.
Any more posts in this thread that will not help achieve a resolution will be dumped.
That includes posts that contain sideline observations and theoretical questions by anyone not directly involved in the disputed transaction.
I will include here, a statement from one of those dumped posts that shows that Jmark is the most instrumental one here in achieving that goal.
Originally Posted by Jmark
I did send Bigs carbs an email suggesting he/they come check out the thread and give the other side of the story. There are always two sides and this one is very lopsided. I was hoping you would back off and that Bigs would join in this "slam fest" and offer up his side in this mess with Trailerking.
Later, mikey
  #40 (permalink)
Old 10-06-2008, 08:18 PM
Bump all the way to the top!
  #41 (permalink)
Old 10-06-2008, 08:21 PM
Jmark's Avatar
Why? Is there more stuff you want to say? If so, please say it to the owner of the company, where it belongs. This has gone way far enough.
  #42 (permalink)
Old 10-06-2008, 08:32 PM
(1)Just keeping others informed on the reality out there.
(2)Same as #1
(3)Been there done that however that doesn't help all the other victims.
(4)It's all true and letting others know. No need to pretend it's not happening.
  #43 (permalink)
Old 10-06-2008, 09:04 PM
Jmark's Avatar
Ok, you've had your say and after reading 4 pages of Google articles about Big's carbs, you are the ONLY disgruntled person I found.
I'm sorry you had a bad experience but things happen. I have not found any other "victims" out there sharing their experiences, so for now, this thread is done. It serves no useful purpose anymore other than you telling and re-telling the same story.
Mark
Closed Thread
Progressive Linkage On Blower Carbs Setup? 5-7heaven Engine 6 10-07-2007 10:30 AM
Offy 6x2 with Ford 8BA carbs? rlackey Engine 8 04-26-2005 06:38 AM
Edelbrock -JET-DeMon-Holley performance carbs tm454 Hotrodders' Lounge 0 03-30-2003 06:07 AM
one 4 barrel carb or multi carbs........... onebadmerc Hotrodders' Lounge 13 02-07-2003 07:56 AM
Edelbrock carbs Barry96vette Engine 3 10-28-2002 02:54 AM
