Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bigwrench3311
Thread: bigwrench3311
Old 10-17-2012, 05:53 PM
LATECH's Avatar
LATECH LATECH is offline
Check the basics as the guys have mentioned earlier in the post.
The coil may have power, but you also need to check to see if it has the ground pulse from the PCM to fire the coil.
The coil needs a ground pulse, and it is supplied by the PCM.
Hook your test light clip to the battery positive, then un hook the plug at the coil. Probe the non hot (not the 12 v + side) side of the coil harness, and crank the engine. It should blink as the engine is cranked.
If it does not the PCM is likely the problem.
If it does blink, the the coil must be defective.
The PCM processes the cam and crank signal and triggers the coil and injectors. The PCM could be defective in the output stage to the coil, or the reference voltage section for the cam and crank sensors has failed, and they arent generating a signal for the PCM to use for coil triggering.
Fact is stranger than Fiction
