bigwrench3311 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 09-20-2012, 03:03 PM
bigwrench3311
1993 dodge dakota no spark changed crk. sensor & cam sync. no changed cam sync. back. have volts to coil coil ohms ok. dist.is turning. eng.is 3.9L. truck is 4x4 auto trans. looking for tips. thanks.
Old 09-20-2012, 07:06 PM
RWENUTS's Avatar
Maybe you need to get this thread moved to the modern electronic engine section in the engines forum.
The Following User Says Thank You to RWENUTS For This Useful Post:
bigwrench3311 (09-23-2012)
Recent Modern Electronic Engines posts with photos
bigwrench3311 bigwrench3311 Introduce Yourself 0 09-20-2012 02:54 PM
