Bimmer IRS? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2013, 12:31 PM
Bimmer IRS?
Hi to all from first time poster.
I was told the some modern 7 and 5 series bimmer's IRS were more or less self-contained unit mounted on a subframe. Anyone got knowledge about those? I knew the old Jag IRS was that way but not a multilink design.
I never seem anyone graft those bimmer IRS on older muscle cars, but the idea sounded interesting if one doesn't have to deal with geometry, mountain point etc.
thoughts?
Old 05-09-2013, 08:05 AM
Anytime you modify suspensions you have to be concerned with geometry. Even though the IRS may be a cradle mounted piece, you will have to consider your track width ( will it work with your car properly without modifying it ), correct installation of the IRS to maintain proper camber gain, pinion angle, anti -squat ect....that would be the basics at a minimum to watch and pay attention to what you are doing. The other thing I would take into consideration is availability and cost of replacement parts... if you are dead set on an IRS and don't have the budget for a performance aftermarket piece like our Fast Track IRS, then I would consider the mustang, T-bird IRS... any way you go it will be some entailed fab work and designing to get it in a chassis not originally designed for it.
Tony...
Old 05-12-2013, 09:24 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I have done some work on an 02 530i including some work on the rear suspension. It is a fantastic setup and I think that it would be well suited for a hot rod swap. The rear suspension assembly hangs on an all aluminum subframe, is easily adjustable (within a relatively small range), rides beautifully and has tons of wheel travel with next to nothing for camber change and toe steer.
I vote yes!
Any Bimmer guys? 83SILVRADO Hotrodders' Lounge 10 01-18-2010 08:32 PM
'93 Cougar IRS, and general IRS question LiftFlat Suspension - Brakes - Steering 4 12-12-2006 02:47 PM
Irs Gr8 '48 bow tie Transmission - Rearend 8 12-26-2005 03:21 PM
The bimmer 1970 CHEVELLE SS 454 Engine 5 12-22-2005 04:17 PM
Gm Irs ??? classic_chevy_guy Transmission - Rearend 11 04-23-2005 06:23 PM
