Binary switch? What is its purpose? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2010, 09:38 AM
40forddgc's Avatar
I installed an air conditioning system in a 55 Chevy and didnt install the binary switch.
1-What is the purpose of the Binary switch?
2-Would it damage the compressor by not installing the Binary switch.
Thanks
Doug
Old 01-11-2010, 12:15 PM
Joe G's Avatar
(I'm assuming you're talking about a typical aftermarket A/C system)
The purpose of the binary switch is to turn the compressor clutch off when the refrigerant pressure gets too high, to prevent damage to components and catastrophic failure. The binary switch will also keep the compressor from coming on when then the pressure is too low, like when the outside temp is too cold, or if the system has lost it's charge.
Old 01-11-2010, 12:22 PM
40forddgc's Avatar
Binary Switch
Thanks for the info.
When I turn on the AC the Compressor squeeks.
1-Does that mean I Damaged it by not installing the Binary switch?
2- If so, can the compressor be rebuilt?
Regards
Doug
Old 01-11-2010, 12:36 PM
Ac
I have never heard of it being called a binary switch. Unless you had some high pressure(over 300) . I would consider the low pressure switch more inportant( this shuts the compressor off when it reaches below 20. Freon leaks are more prone than high pressure in the system, but it should still be installed.
Old 01-11-2010, 03:03 PM
302 Z28's Avatar
With R134 systems the high pressure can get really high (more so than R12)damaging compressor components and blowing hoses, that is why it's important to have a high pressure cut off employed.
Vince
Old 01-11-2010, 05:39 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Yep---what Vince said.
Also---there is a trinary switch. Does the same as the Binary switch with the added feature of sending a signal to the engine cooling fans when the AC is turned on. (handy if you have electric cooling fans, or an auxiliary cooling fan)
Old 01-12-2010, 09:27 AM
40forddgc's Avatar
binary switch
thanks for the reply. Sooooo.. the big question. Did I destroy the compressor???
Regards
Doug
Old 01-12-2010, 10:01 AM
302 Z28's Avatar
Regards
Doug
That depends on how high the pressure got, and how long it was run that high. If your system is still operating properly I would suspect you are OK.
Vince
Old 01-12-2010, 10:17 AM
40forddgc's Avatar
binary
the compressor squeeks when it goes on so i am thinking its toast.
Regards.
Old 01-12-2010, 12:37 PM
302 Z28's Avatar
Regards.
Are you sure it's not the compressor clutch your hearing?
Vince
Old 01-12-2010, 02:50 PM
40forddgc's Avatar
Ac
Yes. i would think it is the clutch.
Regards
Doug
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Light switch question.. APalusky Electrical 9 07-14-2009 07:52 PM
Operation of Vacuum Switch for TCC Lockup JohnTN Transmission - Rearend 1 07-10-2009 11:23 PM
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
? about my neutral safety switch in C10 Streetmaster Electrical 4 08-30-2005 01:41 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
