Binding attachments are generally only used in production settings where one sewing machine is set up to do just one operation over and over. I have the same machine, and do all my binding without any attachments. The reason being, by the time I set up the machine to do binding I could have the binding done. There are a bunch of different ways to do binding, and many different types of pre-made binding from vinyl to polyester to acrylic in different widths and in different configurations (like folded on one side or folded on both sides). The reason most upholstery shops don't use attachments is that they are expensive, and are only good for one width of binding being folded over to a pre-determined width. If you buy a folder that turns 1 1/4" wide binding 1/2", you would then need one that only turns it 3/8" or 1/4", and then you would need more attachments to sew double folded binding which also comes in different widths and on and on and on. If you really want to buy an attachment, buy one that folds the fabric you cut and hems it all at the same time. That would make it the most multi purpose of the bunch. My advise is to stick to pre-made pre folded bindings and skip the attachments. Once you get the hang of it, it's not that hard.
For auto carpet, you generally want to use the same vinyl, leather or Ultraleather the rest of the interior is made out of. In general, that type of binding is done by the "sewing in the ditch" method. Here is a thread that shows this method: CLICK HERE That's not to say you can't use pre-made pre-folded binding of another type, but you may have a hard time finding pre-made binding wide enough unless you use very thin carpet. For a convertible top you would generally use pre-made binding of the same fabric as the top. Here are three kinds of pre-made binding: The one on the left is vinyl folded on one side. The red one is acrylic folded on both sides, and the one on the right is acrylic sewed on one side. Which kind you use depends on the bare edge you are covering. Binding folded on two sides is used when both the inside and outside of what you are binding both show. The middle two pictures are both sides of the red binding sewed to the black binding. This was done on my Consew 226, and if you take your time you can do it free hand also. Another way to finish an edge is to just hem the edge of your fabric by folding it over on itself and sewing it down, like the two pictures of the blue fabric.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 04-15-2010 at 07:42 AM. |
Thanks Dan!!
Had read through the carpet thread before and I think that the sewing in-the-ditch will work great for the hotrod carpeting/mats...I was curious about attachments because the boyfriend threw me a curveball the other night when he asked if I could bind a 12'x12' throw rug for his "man-cave".
Done with most of the interior on the '29, still have cowl panels to do, then I start on the carpeting. You're guidance and suggestions are always helpful.
| Recent Interior posts with photos |
| Making and Binding Floor mats | DanTwoLakes | Interior | 16 | 06-20-2011 08:27 PM |
| 400 SBC Build - Help & Suggestions Needed | S10 Racer | Engine | 4 | 03-19-2008 10:02 AM |
| Swapping 3rd Members, different pinion attachment | BIGSKY | Transmission - Rearend | 6 | 08-13-2007 11:48 PM |
| SITE Suggestions and SITE Help | grouch | Hotrodders Site Suggestions and Help | 8 | 04-09-2007 09:55 PM |
