a bit intimated - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 07:58 AM
Knobie's Avatar
55_crush
a bit intimated
The geometry involved in doing the ladder bar suspension kind of intimidates me. I have been thinking on how I could make things a bit easier for me. I know that leaf spring pinion angle should be about 4 deg and ladder bar approximately about 2 deg. Here is my thought and I am looking for opinions. I would leave the leafs in place and install (tack) the ladder bars at ride height. I feel that if I do it this way, the rear end will be in the original location with only the pinion angle to deal with. I would then remove the rear end remove the leaf spring hardware and weld the unit up. The shock mounts are adjustable up to about 5" Whatcha think????
STAND ON IT!
Old 11-28-2005, 10:49 AM
astroracer's Avatar
Can I ask why you are doing this? Just curious. What is the intended end usage? Street? Strip? If you are drag racing have you tried Cal-Tracs or Slide-a-Link Bars? These are known to work wonders on a leaf spring suspension set-up for drag racing and are a lot more street friendly then ladder bars.
Mark
Old 11-28-2005, 11:34 AM
Knobie's Avatar
55_crush
I understand what you are saying about the Cal tracs. I have the ladderbars setup. I purchased this about two years ago and will install it this winter. The car does see limited street use and It will be run down the track.
STAND ON IT!
little bit of water in my oil smlblcks10 Engine 7 10-02-2005 07:04 PM
Need bit for 53 chevy security bolts myfamiliacc Body - Exterior 4 04-13-2005 11:44 PM
little bit of gas or oil on my rpm airgap brian400ex Engine 5 02-10-2005 11:07 AM
Need a bit of help Hemi_Duster Engine 5 09-06-2004 06:31 AM
352 bit the dust 65galaxie500 Engine 3 03-26-2003 08:10 AM
