Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bizarre High RPM Lean... Why?
  #45 (permalink)
Old 09-19-2006, 03:32 PM
1982 SS's Avatar
1982 SS 1982 SS is offline
Last journal entry: More Cooling fan pictures.
For those of you still following this stroy and those who want to get to the end of the post to see the answer...
A combination of a thorough rebuild and putting epoxy all over and around the plugs, it runs like crazy now. It works real good now, pulls clean to 5500 then next gear and 4700 to the end of the 1320. I may need to adjust the secondary air door tension a little bit, but it is very close to the tension it was when I pulled it apart.
