Bizarre High RPM Lean... Why? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-15-2006, 08:49 AM
Originally Posted by Frisco
I don't know how you are checking/setting your timing but here is how you should be doing it for a non-computer controlled engine.
I know how to set the timing, ive been doing this for almost 30 years
Read the article I posted and learn something.
ps: the 1/4" stud which holds the air cleaner in place works just as well as a golf Tee and its always avail.
  #17 (permalink)
Old 09-15-2006, 08:56 AM
Frisco's Avatar
Glad To Be Here
Well, yes I have learned something from you. You have been setting the timing for almost 30 years and still don't know or understand that the vacuum advance is NOT hooked up when checking/setting the timing.
  #18 (permalink)
Old 09-15-2006, 08:58 AM
I am in total agreement with what you "copy & pasted".
However, this does not preclude the fact that you don't seem to understand that there is no vacuum advance occuring when going to WOT and therefore the Total timing is limited to the mechanical timing only at that time.
Did you miss this?
The loss of vacuum causes the advance... so, you are shy
The vacuum at idle or low revs keeps the plate from advancing..correct?
  #19 (permalink)
Old 09-15-2006, 09:06 AM
Sorry if the arctile I posted is a bit confusing (we had a discussion about the terms used as far as total timing goes)...so call it "Maximum" timing...then it will make sense
My apoligies for not editing the post.
  #20 (permalink)
Frisco's Avatar
Glad To Be Here
If the vacuum advance is connected to a full vacuum source the vacuum advance will pull in additional degrees of timing at idle.
If the vacuum advance is connected to a ported source the vacuum advance will not pull in additional degrees of timing at idle.
The low revs is to prevent the mechanical advance from pulling in additional timing as well as to keep the carb in the "idle" circuit.
  #21 (permalink)
Old 09-15-2006, 09:09 AM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
I'm glad I missed that string of posts cuz it's a Drag car that happens to have license plates! It sees WOT where there in no vacuum and no vacuum advance. It has 38 total mechanical.
For those who think it's the carb, it has a K rod hanger CC rods (about .030 at the tip) 69 main jets and not sure right off on metering rod. I have richened the secondaries and it does not improve. I am still thinking it has to do with fuel getting to the carb rather than the metering. Yes I'm going lean but that doesn't mean the metering is wrong, I'm just out of fuel in the fuel bowl. I'm going to go out and take the regulator apart and see if there is somehting stopping it from regulating properly.
FWIW, before this problem, that car was very close to perfection mixture wise at WOT. This is a recent occurence. I richened it up to that combo listed above just to see if it would help, it didn't. Before it had a P hanger and CE rods (about .041).
  #22 (permalink)
Old 09-15-2006, 09:10 AM
Not correct. The vacuum advance mechanism rotates the baseplate counterclockwise with increasing vacuum which increases the advance under high vacuum conditions. When the vacuum goes lower, the mechanism rotates the baseplate clockwise to retard the timing. The vacuum advance and the mechanical advance are two entirely separate mechanisms.
  #23 (permalink)
Old 09-15-2006, 09:28 AM
I do not run full vacuum for the advance, I use a ported source... so I am correct
Honestly, this forum looked loke a pretty cool place but now I'm not so sure....I posted an excerpt from paper written by one of the top GM tuners in the country and have been bashed because of a difference of a term "total timing and Max timing" and also criticized for a "copy and paste"
Please excuse me for my ignorance................
  #24 (permalink)
Old 09-15-2006, 09:29 AM
Frisco's Avatar
Glad To Be Here
Originally Posted by 1982 SS
The fuel is the factory hardline from the tank to the pump and up to the front where I have used 6 AN line to the the Aeromotive return type regulator, 6 AN to the carb and 6 AN all the way back to the tank.
I have no doubt the pump can keep up with it. It can suck my tank dry in about three minutes (17 gallons later...)
Just a thought. Is the factory hard line from the tank to the pump large enough to supply fuel at the rate your engine needs? Is the tank pickup staying in the fuel under hard acceleration?
If the 6 AN return line offers the path of least resistance, is it feasible that the fuel is returning to the tank rather than supplying the carb at the higher RPM?
Just some thoughts. Not sure of any correct answers.
  #25 (permalink)
Old 09-15-2006, 09:50 AM
A couple of things. If you are going to quote someone, give them credit with a link to the full text. Lars Grimsrud has a lot of stuff in print about engine tuning and is one of the most respected tuners around and wrote this:
http://www.teufert.net/distrib/vacadvspecs.doc
It makes no difference to the VA mechanism whether you use ported or manifold vacuum, it advances the timing when high vacuum is put to it and releases the advance when the vacuum goes lower. It does not do any of the following:
Which is it?
The advance comes in as the vacuum drops
Here's what you pasted from Lars:
When the load on the engine is light or moderate, the timing can be advanced to improve fuel economy and throttle response. Once the engine load increases, this "over-advance" condition must be eliminated to produce peak power and to eliminate the possibility of detonation ("engine knock"). A control unit that responds to engine vacuum performs this job remarkably well.
Light or moderate loads are synonymous with high vacuum and increased timing. When you increase the load on the engine, the vacuum is reduced and the vacuum advanced timing goes away.
  #26 (permalink)
Old 09-15-2006, 10:03 AM
Did you ever think that Lars does not want his papers all over the net?
Thats why I only posted an excerpt
Now I have some words for this board
It seemed like a nice place but was wrong as frisco has been breaking my balls for no rason at all
GO ***** FRISCO!
Guess this will get me banned, easier than asking to have my account removed
Too bad too, seemed like a nuce bunch of guys
Last edited by Jon; 09-15-2006 at 10:56 AM. Reason: Profanity. Please see guidelines at: http://www.hotrodders.com/help/board/guidelines.html
  #27 (permalink)
Old 09-15-2006, 10:05 AM
1982 SS's Avatar
Flamethrower
The factory hardline has been enough for the first part of this season and all of last season. The new pump and regulator have been more than enough for at least half this season. The only other thought I have is that maybe the canister filter I have before the pump has a bubble in it and it shows up high RPM the most. I am going to bypass the filter and see what happens. While I have the line undone, I will blow some compressed air backwards into the tank in case there is some blockage there.
The regulator is fine I just had it apart and looks good. No junk anywhere in it.
Also, BC that was uncalled for. you know where the door is if you are going to be like that. Too bad it happened in this thread though.
  #28 (permalink)
Old 09-15-2006, 11:54 AM
Lars Grimsrud's papers are all over the internet whether we like it or not. His generous work is linked through several Corvette sites, like this one:
http://www.corvetteclub.org.uk/kb.php?mode=cat&cat=3
His email address is linked with each article so you can contact him directly.
  #29 (permalink)
Old 09-15-2006, 12:27 PM
1982 SS's Avatar
Flamethrower
Latest development. I bypassed the filter I have before the pump. I used a piece of hardline and bent it to shape and connected my line from the tank right to the pump (before it went tank filter pump). It is no better than it was with the filter plumbed in. I even un-screwed the gas cap in the event that my tank was being sucked flat. No change. It starts to surge at 4600 and gets worse the higher it goes.
I am at a loss as to how to fix this.
  #30 (permalink)
Old 09-15-2006, 01:42 PM
You're investing a lot of energy and time in your fuel system with few results. Are you sure your secondaries are opening? Have you thought of checking the ignition system? Got good valve springs?
16 y/r son blew engine/step dad says his RPM way too high.... DHancock General Rodding Tech 31 11-24-2005 06:08 AM
high rpm mis john chaffin Engine 3 11-02-2004 03:08 PM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
