Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Black moon discs?
Old 11-10-2012, 04:44 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by Ess El Emm View Post
Right now the wheels have no hubcaps, but that leaves the half shaft nut on the front wheels exposed to the elements, and it is corroding.
Your local supermarket or Walmart or whatever, has small clear plastic bowls, about the size of a coffee cup. Leave 'em clear or spray paint 'em any color you want to on the inside, then glue 'em on with RTV so that no moisture can get to the nuts. Total cost, probably less than 5 bucks. You may even have some in your kitchen that would work.
