Black Oil Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 10:41 PM
New Member
Black Oil Question
hey guys, i changed my oil recently and it was pretty damn black, and i change my oil more often than 3 months 3000 miles, but i do drive pretty hard, its a 350 .60 over and all that good stuff, i was wondering why the motor is so black ?
Old 09-20-2005, 02:48 AM
GoneNova/406's Avatar
oil does turn black fairly quick.i guess some of it would depend on how heavy the oil is and also how hot you run the motor and good of a cooling system you have.if it bothers you try changing the filter between oil changes.that will help to keep it clean and give a fresh quart of oil to add to the mix.you could also try some of that engine flush 3 or4 times a yr.all cheap fixes that may help.i use one of micro screens you put on top of your oil filter to keep particles from flowing thru your oil.also you can go to lowes in the hardware section and buy packages of round magnets for a couple of bucks.i put six of them around the drain of my oil pan and tranny pan.remove them before draining oil and reistall.check the oil for particles.it all helps cheaply.good luck
Old 09-20-2005, 06:56 AM
astroracer's Avatar
What kind of oil? Many synthetics are black when they're fresh...
Old 09-20-2005, 07:41 AM
wide ring end gaps will make oil black a lot faster, there might not be enough combustion gasses getting through the gaps to notice an increase in crankcase pressure but in my experience there will be enough oil contamination to turn it black. Some of the ready to run nonfile fit rings today have some large gaps just to make sure they aren't going to butt when hot. JMO's Bob
High Volume Oil Pump Question Mustangsaly Engine 4 06-11-2005 08:05 PM
BBC 496 Oil Pan question Bee4Me Engine 3 06-01-2005 05:47 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 08:51 PM
Bolt and oil question? HemmiGremmie Engine 8 11-12-2004 07:52 AM
Oil pressure sender question Jag Daddy Engine 5 03-07-2004 07:59 PM
