black plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2008, 08:01 PM
black plugs
I just checked my plugs on my BBC with a 671 GMC blower.I'm afrain to lean out my carbs so I run it a little rich.I didn't replace the cam yet so its still a mild street bumpstick.Could the incorrect duration or lobe separation cause my plugs to soot up quickly?What heat range do you guys suggest.Right now I'm using motorcraft 25 plugs.
Old 06-04-2008, 10:06 PM
BORTI's Avatar
BLOWN 357
Black Spark Plugs
I have the same problem with my blown sbc.But its common with a blower motor,because your not in boost very often on the street your not creating much cylinder pressure to burn all that extra fuel.I put a hotter plug in mine and it helped a little,the only other thing is to advance your timing more.This is the catch 22 with a blown street engine.
Old 06-04-2008, 11:28 PM
Stroke Meister
The tune is very important with any forced induction motor
hotrod black comparison? runn141 Body - Exterior 3 05-30-2008 08:04 PM
Is there a place on the internet Overdriv Body - Exterior 5 09-25-2005 06:47 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
Black Paint Prep Ron M Body - Exterior 1 08-22-2004 12:38 AM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 08:01 PM
