Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - black sand
Thread: black sand
Old 12-23-2006, 10:41 AM
oldred oldred is offline
Bee, That warning about contaminating the sand/media with sealer, oil, grease and undercoating is one that is not mentioned enough. Some years ago I recycled some sand that I had used to blast the underside with after scraping as much old undercoating off as I could but the tar (or whatever that crap is) wound up embedded in the metal surface where it caused some real headaches. It is not as simple as wiping it down afterword because the rough surface makes it a bear to remove and if you don't get it ALL-
