black single stage urethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 07:39 PM
46 chevy pickup's Avatar
46 chevy pickup
HI Guy's
I want to spray my truck with black single stage urethane so I can see all the imperfection.
My question is ,can I just spray sealer over ss or should it be removed.
Old 04-24-2013, 09:12 PM
33Willys77's Avatar
Use a guide coat over the primer and block it. If it comes out straight, paint it and be done. Dont waste the time, material and $$ painting it twice. Once paint is dry, you will need to sand it to put anything on it again. 2 types of adhesion, chemical and mechanical. So, once the paint is dry, there is no way to get the chemical adhesion.
Old 04-25-2013, 05:07 AM
Old Fool's Avatar
Shoot SPI black epoxy on it, makes it very easy to see the highs and lows.
Sands well, and gives great adhesion and protection.
SPI epoxy will have a sheen that looks very much like a new part that has the EDP coating on it.
If you really want to shoot black SS, SPI makes a great one also. But I would not suggest shooting any type of SS on your project, I would use the SPI epoxy.
Here is a picture of dried SPI Epoxy that I shot a couple years ago.
http://img.photobucket.com/albums/v6...8_094044-2.jpg
Acrylic Urethane single stage elcaminodragster Body - Exterior 3 05-31-2009 06:19 PM
Single stage urethane cure time RLDSL Body - Exterior 2 02-25-2009 10:22 PM
Single Stage Urethane Restoration Shop?? Geradmg Body - Exterior 2 06-29-2008 04:46 PM
Flatening NASON single stage urethane 10Tonhammer Body - Exterior 1 05-08-2007 09:34 PM
Urethane Single Stage Paint/Primer SHIFTY101EASY Body - Exterior 3 02-07-2007 03:52 AM
