black smoke porsche - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2006, 06:41 PM
black smoke porsche
hi everybody,i just bougt a 1986 porsche 944 non turbo four cylinders engine the car as only 65,000km and it as been put away for 12 year .the probleme is when i started the car it is ok but when the engine reache is normal temperature it started to smoke,i notice that some oil is going into the intake ,could it be that the piston ring are stikking or could it be some sensor that are defect,any advice on what i should do or check tank you .i cant wait to ride this car.
Old 08-03-2006, 08:18 PM
Wiki Edits: 31
non functioning O2 sensor most likely, black smoke means running rich, )2 sensors don't work until there up to temp.
Old 08-04-2006, 03:58 PM
Duke of Cruel's Avatar
Car nerd
Hi there,
put in an chevy ls1/2/6/7, they sit perfect in there, and is more reliable than the porsche engine.
The corvette motors is also with transaxle, and fit more or less straight in.
If it is to much of a project for you then look here
Renegadehybrids.com they hav some nice kits, a bit pricey but nice. Have a 928 with an warhawk ls engine and it works.
DoC
Old 08-04-2006, 05:59 PM
Everything is HAMMER!
I was just gonna say drop a chevy engine in it jokingly, but i had no idea you seriously could!
Old 08-04-2006, 09:20 PM
Car nerd
it fits perfectly in the engine bay, light weight and strong.
DoC
Old 08-05-2006, 06:00 PM
Wiki Edits: 31
A SBC will fit with a 944 Transaxle also.
Old 08-06-2006, 06:00 AM
Car nerd
sbc will fit, but it is very heavy, and does not suit the 944īs handling. and a good ls1 corvette is a little over 2k.
DoC
Chevy 350: Black smoke, is it oil or gas STATUTORY GRAPE Engine 14 06-17-2006 07:07 PM
Black Smoke When I Stomp On It mempis Engine 4 02-04-2006 09:50 AM
Black Smoke Out Of Breather Cap? SBC-S-15 Engine 3 06-13-2005 04:37 PM
Black smoke screamin340 Engine 2 03-24-2005 11:48 AM
black Smoke and Stalling jrm123180 Engine 11 03-09-2004 11:41 PM
