black trim re paint questions, flat or gloss black? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2010, 08:11 PM
so what does everybody use when re painting there cars? do you use gloss black on all the trim? satin black? or base coat with a satin clear or something? gonna paint my 85 light regetta blue within the next 2 weeks, but unsure If i should use a flat black or a gloss black on all the trim, thanks guys
Old 04-10-2010, 08:30 PM
ericnova72's Avatar
More for Less Racer
SEM Trim Black, it is like a satin finish, something like 30% gloss. Mimics the factory trim black real well.
Old 04-10-2010, 08:43 PM
IS or CAN you put clear coat over that?
Old 04-10-2010, 08:54 PM
TucsonJay's Avatar
That would make it a gloss finish.
I use this paint for a lot of things.... exterior trim ....frames .... engine compart,emts ....the inside of bike fenders ....etc.
It's a one shot deal, needing no primer, and the adhesion is very good.
I think you can buy it in either enamel or lacquer base.
Old 04-10-2010, 10:14 PM
woulsent the single stage SEM out of the can scratch pretty easy? I would like to put a clear over it to protect it, but if it isent nessacery, well....
Old 04-11-2010, 09:51 AM
TucsonJay's Avatar
It is meant to be an exterior finish for trim parts. It has been pretty tough, and I've never noticed it scratching easy, after using it for about 20 years on countless jobs. I use the lacquer formula, but I imagine both are good.
Flat Black Paint for Fiberglass. scrimshaw Body - Exterior 6 02-25-2008 08:03 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
flat black hood on a gloss black car Dubz Body - Exterior 23 07-14-2004 08:01 PM
Flat Black Paint sully Body - Exterior 11 01-14-2004 04:19 AM
Flat Black Paint trick66 Body - Exterior 10 03-15-2003 05:13 PM
