Black Work Van with old removed decal fade showing up- Way to eliminate this? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-06-2012, 04:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Originally Posted by 777funk
That's what I was thinking.
Ok... new thread. Cheapest way to paint this thing black. I'm guessing SPI Clear will be a great option. I've been wanting to try that product for a while.
A van is a lot of paint!
Ok some might not agree but the cheapest black paint job i know of is to use the SPI black epoxy primer and then universal clear over that..shines good and is holding up after 5 years in service..
Sam
  #17 (permalink)
Old 02-07-2012, 06:45 AM
deadbodyman's Avatar
Wiki Edits: 11
Yup and now Barry's put a UV protection in his epoxy so it can also be used as a hot rod black with no clear.
.....Ya gotta love that guy....
  #18 (permalink)
Old 02-07-2012, 07:39 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
regardless of what you use you need to buzz it down good with 80 grit then epoxy it ..
  #19 (permalink)
Old 02-07-2012, 09:51 AM
What's the best way to buzz it down with 80 grit?
I've got a Dynabrade, a National Detroit Inline 1/3 sheet sander, and a right angle buffer polisher (rotary).
Wet/Dry 80 or stearated dry paper?
  #20 (permalink)
Old 02-07-2012, 10:03 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You'll need to use the 80 grit with a D/A sander. And then after priming use 320 grit on the D/A . If repainting in black. I would reprime after the D/A sanding and block sand with 400 wet, using a guide coat. Black will show every imperfection.
  #21 (permalink)
Old 02-07-2012, 10:04 AM
Wiki Edits: 3
I would use the dynabrade to remove the paint and feather back to good paint. In fact I would dynabrade the whole thing after a good scrubbing with Dawn and hot water..
Sam
  #22 (permalink)
Old 02-07-2012, 10:10 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Sam
I don't know what kind of dynabrade you have. I just checked the website, and there are many different dynabrade products. If you have a dynabrade orbital sander, it will work just fine. Same action as a D/A .
  #23 (permalink)
Old 02-07-2012, 12:43 PM
I have a Dynabrade Palm (DA orbital sander) with a 3/32" orbit.
I've got several air sanders of different types and an electric Random Orbital with two different orbit sizes.
  #24 (permalink)
Old 02-09-2012, 06:56 AM
Wiki Edits: 11
I'm going to have to disagree here on two points First off epoxy isnt the best choice For this job for two reasons ,it takes to long to cure and it although it will fill it wont fill like a 2K build primer...two coats of build primer will be plenty and it'll ready for sanding the next day instead of next week....
Second 80 is a bit to agressive ,all you want to do is level the surface a little and provide a rough enough surface for the primer to stick,...Sure 80 will work but it'll take the paint down to the metal in many spots and excentuate and actually cause divets and waves from sanding ,especally from someone with little experiance using a DA,not to mention the 80 grit scratches themselves that'll now need to be filled and sanded , its just not necessary to get rid of the ghost edges from the vinyl,(after all its only the edges were talking about that'll show) ,your just trying to fill that little step.
Theres no sence making this a big job ,it isnt going to be a show truck and trust me, the last thing in the world you want to do is strip a van, you just want the have a nice truck and do it yourself...Over the years I've done hundreds of trucks and vans like this it works great and its the fastest way with the least amount of work....also the cheapest.....
regaurdless of what you sand with whether its 80 or 180 you cant just sand then prime ,it'll have to be 320 sanded about 4 inches farther out than you sanded with the rougher paper other wise you'll be spending the whole day sanding primer off unsanded paint...always "outline" with 320 before priming..I just thought I'd throw that in there because it never seems to be brought up but its something that must be done.like using a wax& grease remover ,sometimes we over look telling newbies this because we just do it automaticly without even thinking about it. its important ...
  #25 (permalink)
Old 02-09-2012, 07:09 AM
shine's Avatar
SPI Thug
during the 80's i ran close to 10 units a day on average and they were new . at the end of the year we had to deal with the two tone crew cabs. 10 to 15 a week. the only way to get rid of the tape stripe was to remove it and buzz the area with 80. you can not prime it away. it is the metal that is effected and 80 is needed to get rid of the ridge . you can prime and block all you want but once it hits the sun it will ghost back. as for epoxy i can shoot today and sand tomorrow .
  #26 (permalink)
Old 02-09-2012, 07:22 AM
Also DBM, I'll be spraying the whole van. I don't know if I mentioned that or not. But the entire van is pretty faded. It needs new paint. I suppose maybe I could sand back the clear and buff. Last time I just buffed with a medium compound and that took the faded look away but it came back.
I'm thinking the only way to get rid of it is to sand and repaint. I think my new plan is:
-Sand the decal areas to metal with 100 grit (I have lots of 100 disks).
-Sand the metal to 180 to refine the 100 a bit
-Sand the whole thing to 320 and scuff all paint
Then:
-Spray two coats of black SPI epoxy primer
-Spray two coats of Univeral Clear
If all is ok call it done. If it's got anything I don't like, sand it out and spray another coat of clear.
  #27 (permalink)
Old 02-09-2012, 07:24 AM
Wiki Edits: 11
Back in the 80's we were still using lacquer primer so that dont count.and a two tone painted edge is totally different ,its a much thicker edge...and nobody can can change the cure time of epoxy,it'll take 3-4 coats using epoxy ,two coats with 2k...
I'm not trying to pee you off shine I'm simply disagreeing with you and offering an easier ,cheaper and faster way ...as I said before your way works too...
  #28 (permalink)
Old 02-09-2012, 07:32 AM
shine's Avatar
SPI Thug
at first mike we would feather the edge down . but the 1/2 tape line came back. not the paint edge . buzzing a 2 inch area down to metal was the only cure.
i use only epoxy to prime with . i do one good double coat then block the next day .
i would also not clear the black epoxy. a good ss black will serve you better.
  #29 (permalink)
Old 02-09-2012, 07:33 AM
Wiki Edits: 11
Then:
I wouldnt use the epoxy as a base coat and then clear if your trying to save a little money .use a single stage black no clear,that'll run you 200.00 The epoxy alone will cost that
  #30 (permalink)
Old 02-09-2012, 07:54 AM
Wiki Edits: 11
Thats tough enough Shine ,When I lived in Fla I had the misfortune of being within 10 miles of one of the biggest van conversion companies in the country and those things were the worst to do repairs on ,very shotty work and it seemed like everyone had one and just about all of then had those decals slathered all over them we had to do them quick and get them out ,they took up to much room...I have one in my shop right now ,had to build six 4' horses just to paint the roof,talk about a major PITA....Its the last dang van I'm going to do ,my back is too old for this stuff anything that makes a crappy job like this easier and faster I'm game for...I almost hired someone....almost
Kustom Shop's black cherry kandy over black diamond metallic for dark reddish-black? 350cruiser Body - Exterior 3 08-03-2010 08:02 PM
Paint a fade holeshot92 Body - Exterior 1 12-31-2008 09:26 PM
Fade away paint oldcpecdr Body - Exterior 5 12-15-2008 09:51 PM
Lots of work finally showing progress D9ZZ Body - Exterior 4 09-23-2008 01:19 PM
Fade Away Paint ScottRods2945 Body - Exterior 0 08-22-2007 01:45 PM
