blank rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2005, 07:35 PM
blank rotors
Ive got a 58 apache with a RBs monte carlo clip that i bought as an abandoned project. It was a pretty cool deal since it came with a 3.55 posi rear and all the chassis work was done by a pro, unfortunately the rear end is the six lug original and the front is ,obviously five lug. Seems like the previous was conflicted as to what bolt pattern he wanted to run , and with what I have so am I. What should I do, sell the brand new posi rear and buy a 70-81 camaro 10 bolt or should I try to find 6 lug rotors to work with the monte spindles? Id rather swap the rotors for cost effectiveness (I dont mind the limited wheel selection) , but where do I find 6 lug rotors that are compatible with monte spindles? Anybody out there know where I can get blank rotors that I can have machined with the corect bolt pattern?
Old 03-13-2005, 08:28 PM
abstruse dutch uncle
Easiest and cheapest might be to pull the axles and have them drilled for the front pattern.
redrilled rotors 6speedwagon Suspension - Brakes - Steering 1 11-20-2004 08:44 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
American Made Mustang II Rotors Sweet-34 Suspension - Brakes - Steering 2 05-17-2004 05:29 PM
Can I make my own cross drilled rotors? jacobm99 Suspension - Brakes - Steering 4 03-01-2004 07:44 PM
buying rotors APACHEMAN Suspension - Brakes - Steering 5 08-06-2003 07:51 PM
