Blasting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 02:00 PM
Mac88's Avatar
"Drive It Until It Breaks"
Blasting
I need a little advice from the body experts out there. I have my í68 Mustang stripped down. The trunk pan is completely rusted out, I see a few pin holes in the driver-side floor plan, and the bottom of the rear panel is rusted out. So, Iím going to just going to replace the complete floor and trunk pan. The question I have is about soda blasting. Iím thinking I should get the car completely blasted including undercarriage to get rid of all the rust and grim so I can see exactly what Iím working with. But since I need to have the car primed shortly after itís blasted, should I have the pans put in first? If I had the money, I would do it all at one type, but Iím assuming that will be a big job and cost a pretty penny!!
Old 04-21-2013, 02:33 PM
life is a temporary assignment
Originally Posted by Mac88 View Post
I need a little advice from the body experts out there. I have my ’68 Mustang stripped down. The trunk pan is completely rusted out, I see a few pin holes in the driver-side floor plan, and the bottom of the rear panel is rusted out. So, I’m going to just going to replace the complete floor and trunk pan. The question I have is about soda blasting. I’m thinking I should get the car completely blasted including undercarriage to get rid of all the rust and grim so I can see exactly what I’m working with. But since I need to have the car primed shortly after it’s blasted, should I have the pans put in first? If I had the money, I would do it all at one type, but I’m assuming that will be a big job and cost a pretty penny!!
You can go either way,, I would put the pan in first,,,, As far as soda blasting,,,, That ******* is a mess... I did one car that was soda blasted,,, It came to me a big mess,, Not sure if someone didn't finish the job are what... But never again,,, Just look into it before jumping in with both feet,,, I would just replace what needs to be done first..
But then again if you blast it first,, You may need to change more..
Old 03-19-2014, 12:58 PM
Mac88
Soda Blasting will not remove rust. It works well with removing paint, but not rust.
Old 03-20-2014, 04:25 PM
Pats55's Avatar
You don't necessarily have to prime it . If the car is to be indoors just wipe it down with a good quality metal prep and will stay rust free in the garage for a year. Be sure that the prep you use leaves a zinc phosphate film
Sandblasting, soda blasting, media blasting? 60Metropolitan Body - Exterior 33 09-17-2014 08:48 AM
Soda blasting 1951sms Garage - Tools 2 08-30-2012 06:59 AM
Blasting chase1994 Garage - Tools 34 01-29-2011 10:43 AM
Sand Blasting HUMPTYDUMPTY Garage - Tools 1 12-16-2008 07:14 AM
Sponge Blasting kltrev Body - Exterior 6 04-16-2008 09:30 PM
